LED lights & "lamp out" on overhead???
I have a Hillsboro aluminum flatbed on my 07' cab & chassis & when I pulled the 6 brake/turn signal lights out (2"X6" oval) & installed all LED lights back in their place I'm getting a LR & RR lamp out reading on the overhead?? I know it's because the LEDs don't draw enough current so therefore the computer thinks theres a bulb burnt out, but my ? is how would one go about running LEDs w/out having this problem????? thanks alot, Dusty
Hey Dusty this webpage here: http://autolumination.com/equalizers.htm has your fix. I spliced 6 ohm "load equalizers" on all four corners of my truck to get rid of the lamp outs and fast blinkers. They're easy to install: http://superlumination.com/images/leds/installation.jpg Or if you don't want to splice into your sealed harness figure out which "flasher" you need and go that route.
Hoss
21
Dec 3, 2016 02:49 PM
Diesel Junkie
Dec 23, 2014 03:01 PM
Pickle
Mar 26, 2005 11:57 PM
Palmetto_kid
Mar 14, 2005 10:07 AM
CHarlan
Aug 6, 2003 08:40 PM
