King Shocks
#31
I wasnt gona argue but I coulda swarn that Don told me I would loose some payload. With a 20,000 lb + gooseneck on my truck it will sag some but not bad enough to worry about, even with the leveling kit it isnt that that far nose up, if I you dont loose any payload with the minipacks I would definately look into that.
Anybody else have any opinion on this?
(sorry for the highjack)
#32
#34
Yeah, you'll lose some payload, but not nearly as much as with a full pack.
#35
As for the Lorenz Dual Purpose leafs. What I meant was w/ the bump stops you have a higher spring rate than stocker leafs. You'll still sag w/ a load.
Anyways, we seriously hijacked this guys thread.
#36
I have a little data on the mini-packs... I haul a 1600 Lb slide in camper. With the stock springs (with lift blocks) it would sag 1" when I put in the camper. After I installed the min-packs and pulled out the big overload bar it now sags 1 1/2". For what I haul and how well the truck handles now, I consider that a very considerable trade off.
#37
Getting ready to upgrade to king shocks....anyone have the correct valve rating? I'm running carli 3rd gen coils in 2nd gen(heavy replacement front bumper). Thanks!
#38
Anyone rebuild and know the valve or shim setup for king shocks for those running carli or thuren coils? Or do I need to ship my kings to them for setup? Any help is appreciated.
#40
Unfortunately, that info is proprietary to Carli/Thuren.
I don't think Sage or Don would appreciate someone posting this info in a public forum.
A re-valve by either shouldn't be too expensive.
#42
I'm running Don's stage three in front and two in rear with a little tweak for the camper. He went with two in the rear due to the Carli LT's. My axle weights w/camper are 4400# front and 4000# rear. The single cabs are quite a bit lighter.
EverydayDiesel
08-19-2007 09:38 AM
ptgarcia
07-12-2006 01:27 AM
