Juice
Old Nov 28, 2005 | 12:08 PM
genros's Avatar
Juice
Hey guys
Im hooking up a juice today in a 05. ANy advice? Its a juice a2 combo.
Old Nov 28, 2005 | 01:24 PM
Sevir's Avatar
the only hard part is tapping the manafold. Drill and tap it with the engine at idle so all the shaving blow right out. Also it gets hot once you drill the hole so get you a pair of gloves. A little trick i picked up while tapping is use a regular tap to get the threads started then use the 1/8" NPT to complete it. Also leave about 4-5 threads exposed. Dont tap the NPT all the way or you will end up having to weld that housing on the manafold. Other then that its a pretty easy install.
Old Dec 1, 2005 | 09:29 PM
Supertrucker's Avatar
Hey guys I am a newby to this forum but I have the juice too. I took and drilled it with the motor off and took a magnetic tool and got most of the shavings out and started it up. Have had no problems so far in the past 10 months since I put it on. The only thing I had a problem with was the little bracket that the attitude monitor mounts to. I accidentally stripped the one set screw and ended up drillin it out and puttin a larger, longer screw all the way through it. Has held up just fine.
5.0 Mustang Man
Oct 21, 2008 02:50 PM
SconsinSmoker
Feb 12, 2007 09:15 AM
bighornram
13
Nov 2, 2006 08:28 AM
razor6
22
Jan 20, 2006 03:43 PM
djcheez
Oct 15, 2005 04:13 PM
