Interesting findings....
Old Jun 20, 2007 | 08:15 AM
trik396's Avatar
I listen to the shut down of my engine from time to time... I can hear the turbo spin and slow down to a stop by putting my ear to my AEM filter. After shutdown, it normally takes 10 to maybe 15 seconds before it slows to when I cannot hear it anymore and I assume it has almost completely stopped. Recently, thru doing research on Bobistheoilguy.com, I purchased some LC20 which is an oil additive. I put 6oz in my engine oil. Here is the crazy part. Everything else remaining the same, temperature, shutdown time, etc., my turbo spins for 25 - 30 seconds before I cannot hear any more spinning. Can this oil additive be that beneficial? Added some to my wifes car and she never notices anything but she now tells me it's running smoother.
Old Jun 20, 2007 | 08:31 AM
rockdonon's Avatar
My wife's 7.3 Excursion does the same thing but I hear it through the tail pipe. No Kitty and straight through Muffler. Have not heard it on the Ram though. (Ram has the Kitty). I woud have to think that the Mo spin the Mo better. If I can find LC20 I will try it in the 7.3.
Old Jun 20, 2007 | 08:47 AM
RoadRacer's Avatar
The extra spin time means less friction,and that means less metal to metal contact and that means longer lasting parts and if you have an engine temp gauge you should see a lower oil temp and that will really payoff in heavy traffic or in a heavy tow load,or in some heavy duty drag or pulling races.
Old Jun 20, 2007 | 09:28 AM
dodgezilla04's Avatar
maybe i should research too. may be beneficial in the long run.
Old Jun 20, 2007 | 10:32 AM
t-boe's Avatar
Where do buy this stuff?
Old Jun 20, 2007 | 10:42 AM
trik396's Avatar
http://www.lubecontrol.com/
Do some research at bobistheoilguy.com
Old Jun 20, 2007 | 10:47 AM
rustyshakelford's Avatar
stuff sounds pretty interesting
brett
Old Jun 20, 2007 | 11:42 AM
trik396's Avatar
I just added 2oz to my trans also... It can be put in anything that needs oil from rearends, trans, etc.
Old Jun 20, 2007 | 03:06 PM
bigcat83's Avatar
HMM so have you have put it in everything take a oil sample and see if numbers are diff.
Old Jun 20, 2007 | 03:07 PM
dale29's Avatar
Wonder why you have to keep adding it at 1k intervals?
It does sound interesting..... may be worth a try.
Old Jun 20, 2007 | 03:27 PM
trik396's Avatar
No... I just ran a sample to Blackstone a few hundred miles ago. Maybe in a month or two it'll be time again.
1oz every so often to replenish the additives that get depleted...? probably?
Dodgezilla
36
May 31, 2008 11:36 PM
mainiac
May 27, 2008 10:22 AM
wap
Dec 29, 2006 06:29 PM
GreyBoy
Oct 9, 2003 11:17 AM
