Interesting rail pressure findings
Old Dec 28, 2006 | 03:52 PM
wap's Avatar
wap
I was hammerin on my truck last night just for fun and in 4th, 5th and 6th gear I got the rp up to the 27,500 mark on my dipricol rail guage.
The interestin thing to me is that I had my tst on standard 4/2 and my mp8 OFF turned completely turned down but still on the truck. After the first time I made sure the mp8 was off then after the second time I made sure that somehow the tst rp was not on and it in fact was not.
Everytime I saw the high readings I was way into the redline. It is hard to watch all the guages at once but I would say between 3100 and peak, wich is about 3400 I think.
Anybody have any explanation for me?
Old Dec 28, 2006 | 04:13 PM
boostjunkie1's Avatar
Stay out of that RPM Range and you should be fine! What is your Reading while having the Modules turned on???
Old Dec 28, 2006 | 07:06 PM
qzilla's Avatar
From what I understand dipricol is having some serious issue with the stepper motors used in these gauges.
I would take that 27,500 reading with a grain of salt, especially with the MP8 off.
Old Dec 28, 2006 | 09:06 PM
wap's Avatar
wap
boost, thats just crazy talk, how am I supposed to NOT hit the redline?
q, interesting, this is the first I have heard of it, I would like some more info if anybody has any.
Old Dec 28, 2006 | 10:16 PM
973604x4's Avatar
Yep DiProcol is having issues.
I ordered my RP almost 3 weeks ago now...got notification today that their recent batch of gauges had lots of issues...so backorder it is. No fun when I am trying to finish everything on my truck by 1/12!
Old Dec 28, 2006 | 10:26 PM
Wink
[QUOTE=wap;1271769]boost, thats just crazy talk, how am I supposed to NOT hit the redline?]
------ Before you hit the 3000 RPM Range----------------------------------Let off the throttle!! Just a thought tho- !
Old Dec 29, 2006 | 06:38 AM
wap's Avatar
wap
Quad/97 is there anything we can do to see if we are havin issues? And if we are is there any type of fix?
boost, so your tellin me if some guy in a honda civic is racin you you are gonna shift before 3000 rpm is he happened to have a turbo and nitrous and it happened to be a close race?
Old Dec 29, 2006 | 10:53 AM
cquestad's Avatar
My gauge has acted funny a few times...
The next time I started my truck...it was back to giving me the readings I expect. It was in the cold too...when it acted up.
Cruzing at 26,000 psi? Ya right. Spiked past 30,000 psi...ya right.
Something was fishy....turned the truck off, started it back up...and it was like it reset and everythign was as expected.
Old Dec 29, 2006 | 11:35 AM
973604x4's Avatar
Call DiProcol is all i would know to do.
Old Dec 29, 2006 | 03:27 PM
Wink
NO----- what I'm telling you is that if you are concerned about the Fuel Pressure------ you NEED TO BACK OFF THE THROTTLE BEFORE YOU GET TO THAT RAIL PRESSURE!!!! It is your call in the end-------but hey, is that ricer with nitrouse and turbo really worth having to rebuild your motor/replace injectors???? NO! I understand where you are coming from, in the sense that you have built your Truck to go fast and that the Rail Pressure is holding you back in your mind----------"IF YOU PLAY WITH FIRE----YOU WILL GET BURNT!!
Old Dec 29, 2006 | 05:29 PM
no_6_oh_no's Avatar
It's not unusual to see that pressure especially not at those rpm's. It ain't good for the injectors and relief valve, but it will make that with stock programming.
Race or no, you are doing yourself or truck no favors by going that high in any gear except 6th. Shift at 2900 and you will probably gain ET and the rail pressures will stay manageable.
You won't out run a ricer top end but you can make them give up early.
Old Dec 29, 2006 | 06:25 PM
morkable's Avatar
My guage is perfect,, never a burp, matches up exactly with the dodge portable box that I borrowed (cant remember the name of it)
Kevin
Old Dec 29, 2006 | 06:29 PM
wap's Avatar
wap
Just to make sure we are clear I was bein sarcatic about the ricer, and top end is no good, 104 is all I can get on gps.
I can definately drive around it but I guess the point was I didnt think these trucks would run that much pressure on stock pressure settings.
cquestad, have you talked to Doug about this? Also what does your truck cuise at? I think mine is close to 20k.
no 6, your right I prolly would shift sooner but I was just playin and I honestly wanted to see how high my rail pressure would go with no rail pressure mods turned on.
Dodgezilla
36
May 31, 2008 11:36 PM
mainiac
May 27, 2008 10:22 AM
trik396
Jun 20, 2007 03:27 PM
GreyBoy
Oct 9, 2003 11:17 AM
