Injector Tube Nut Size?
Old May 14, 2007 | 06:06 PM
cquestad's Avatar
Help...can't remember...what is the injector tube nut size?
Thanks...
Fuel Line Torque?
Old May 14, 2007 | 06:53 PM
53 willys's Avatar
Thanks...
Fuel Line Torque?
it takes a 3/4" wrench I do know, but I don't know the thread size??
I could not find the torque spec, just snug them up
Old May 14, 2007 | 07:34 PM
wap's Avatar
wap
Thanks...
Fuel Line Torque?
I got injector install instructions that I THINK have all the specs and what not. If you need a copy just pm me your email and I will send em to ya.
Old May 14, 2007 | 07:42 PM
metal_miner's Avatar
19 mm or 3/4"
22 ft-lbs
Just "snugging them up" is asking for leaks, especially with the high pressures that will find their way through any weak seal from either over or under-torqued fittings.
Old May 14, 2007 | 08:54 PM
53 willys's Avatar
Originally Posted by JStieger
19 mm or 3/4"
22 ft-lbs
Snug= equals 22ft-lbs.....22 foot pounds is nothing.
the flare on the fitting is what makes it seal.
snug them up you'll be fine
I have never torqued a injector line and never had one leak either......
Old May 14, 2007 | 09:43 PM
PourinDiesel's Avatar
The 24mm hpc nut is 50nm.
Old May 14, 2007 | 10:46 PM
CReed's Avatar
The Injector Tube Nut is a 15/16 and torque to 22 ft-lbs. The Injector Fuel Lines are 19mm or 3/4 we use a 3/4 line wrech and a 3/4 crows foot on the back 2 lines makes it cake less headaches. Make sure you follow steps on injector install or you may not seat the tube into injectors right and that will mean fuel leak and you dont want that.
Old May 14, 2007 | 11:56 PM
I'm happy for you!
I'd rather torque them per spec after having an installer (shop will remain un-named) not torque them properly using German gud-en-tite method. The end result of this was a few gallons of #2 sprayed around my engine compartment from the relief valve as well as #1 injection line. I had to buy a new #1 injection line because one sealing surface got scored by the high pressure leak. The other end sealing surface got scored too as it appeared that the person didn't use a backup wrench to prevent the line from twisting.
That being said I have used your snug method when I didn't have the correct torque wrench and crows foot to access the CP3 to fuel rail injection line, but I never got on the throttle until I could torque the tube nuts properly (not more than a day later).
Here are the injector install instructions that WAP probably refered to earlier:
http://www.glacierdieselpower.com/im...ectInstall.pdf
Old May 15, 2007 | 12:08 AM
53 willys's Avatar
I'm happy for you!
That's why I do my own maintenance...the German gud-en-tite method has worked for me for 10 years now of course I still use my torque wrench on the stuff that needs it.
Nice instruction's
Old May 15, 2007 | 12:12 AM
Me too...
Why pay someone else to screw it up if I could do it just as easily!!!
Old May 15, 2007 | 12:13 AM
53 willys's Avatar
Me too...
yep
Old May 15, 2007 | 12:50 AM
tbarbee1's Avatar
Nice instruction's
Very classy Mark
Old May 15, 2007 | 06:22 AM
wap's Avatar
wap
That is the instructrions I was refering too, I dont have a link though, I fellow member emailed em to me so that is how I pass them along.
Old May 15, 2007 | 09:37 AM
cquestad's Avatar
Thanks...I ment the 24 MM one...lol.
Justin...you the man.
I got (whoops) when I saw the price for a complete set of stubby's...
So I bought another complete set of full length box ends from Craftsman for 1/2 the cost...and cut them all down to length (the longer ones became stubby open ends and stubby box ends)...and slotted the box ends to make them pipe wrenchs. Best set of stubby's yet!
wisconative
May 13, 2013 07:20 AM
Clane
Jun 2, 2012 03:31 PM
Onemoparnut
Oct 1, 2010 05:54 PM
fatt
Feb 19, 2010 05:33 PM
Dean Snow
Sep 21, 2007 01:18 PM
