Injector problems again!!!
Old Oct 5, 2009 | 07:17 AM
Dave04600's Avatar
I installed a used set of injectors in the truck this weekend and it didn't work out so well. With my old set my RP wouldn't go above 12k at wot. Now RP is where it is supposed to be but the truck sounds like crap!. At idle it is ok but anything after that it has what sounds to be loud injector noise. It is there at part throttle thru wot. I checked the valve lash to rule that out. The oil level doesn't seem to be rising, or it is very slowly. Any ideas on what to do now?
Old Oct 5, 2009 | 07:40 AM
Floridacracker's Avatar
i have the same problem being that i can't get above 13k about how much power or time did u lose from this.
did u have the injectors tested first
Old Oct 5, 2009 | 07:54 AM
Brian Lent's Avatar
I have read that a missing copper washer on an injector can cause a loud tap. Maybe you double checked that already.
Old Oct 5, 2009 | 11:26 AM
Dave04600's Avatar
the truck was way down on power. copper washers are def on there. it was a pita putting them on.
Old Oct 5, 2009 | 03:03 PM
rich's Avatar
good injector bodies but bad tips and they were for your motor right. their was an injector change in 04 when they went 04.5
Old Oct 6, 2009 | 08:54 AM
XLR8R's Avatar
X2... non re-entrant injector spray angles on your 555 motor's re-entrant piston bowls could do that.
Old Oct 8, 2009 | 06:43 PM
Dave04600's Avatar
I don't think it is the tips they came out of an 05. the pn on the tip was 1039 i think. I decided to take them out and send them to don to get fixed and upgraded to flux 2. I think i am just going to sell my old ones on ebay.
Old Oct 8, 2009 | 08:36 PM
Spooler's Avatar
Ah, so your truck is actually an 04.5 truck. Your signature says 04' and then 325/600. The HO motor of 04' was 305/555. If I am right, fix your signature. You had me confused for a moment.
DJ Turbo.
Oct 13, 2011 09:11 PM
HONDA99
Apr 29, 2010 12:06 PM
Steven K
Jun 4, 2009 10:32 AM
b84u
Feb 20, 2006 01:04 PM
Sean S
Nov 15, 2002 12:25 PM
