injector problems?
Old Oct 19, 2009 | 06:53 PM
DPatton's Avatar
injector problems?
well the truck here recently just started having the long crank issues. its spinning fast just taking a while to start up, now the son of gun wont fire. No fuel in the oil, have fuel in the filter, she just wont hit. Im feared that this is a bad injector or few. What do you all think? Thanks in advance for the help.
Old Oct 19, 2009 | 07:04 PM
Rpainter's Avatar
sounds like one or more of the injecters are bleeding fuel back and will not let the system build pressure
Old Oct 19, 2009 | 07:08 PM
DPatton's Avatar
thats what i was thinking. I was gonna sell the truck but if i gotta put injectors in might as well keep the sucker.. Who is a good dealer to go through to get some F1 stix? IF i gotta spend the jack might as well spend it on the best.
Old Oct 20, 2009 | 03:47 AM
TexasCTD's Avatar
All of Don's dealers are fine.
No matter which injectors you get.....you need to filter your fuel better. I don't see anything in your sig...but the stock fuel filter is not enough. I'd suggest a filter head mounted with a CAT 2 micron filter somewhere after your stock filter and before the CP3. It will help save your injectors in the future.
Old Oct 20, 2009 | 12:11 PM
DPatton's Avatar
Yeh i havnt had any money to put an airdog on there yet.. Things are getting tuff and now the injectors go to crap.
Old Oct 20, 2009 | 01:23 PM
dieselfreak21's Avatar
It is likely the injector but have you checked the fuel pressure from the lift pump?
Old Oct 20, 2009 | 03:57 PM
Rpainter's Avatar
clean fuel is better for the injectors but not the only way to kill injectors. I have a 20 micron pre-pump filter,the factory fuel filter and water seperator and then a 2 micron fuel filter and a second water seperater and I still cracked a body last month. No programmer or pressure box
Old Oct 21, 2009 | 12:25 PM
surfram's Avatar
I think you would be seeing some smoke if an injector went bad. If you still have the filter canister mounted lift pump, it is dieing or dead. My original lift pump lasted 81900 without any programmers or chips.
Old Oct 21, 2009 | 12:43 PM
Diesel87's Avatar
I would check the lift pump first. I had an 02 that did the same thing and it was the lift pump.
Old Oct 21, 2009 | 02:07 PM
tcr's Avatar
tcr
Had an 04 AND 04.5 do the exact same thing, both were bad filter mounted LPs. I didn't think 04.5s still had them, but some do.
Old Oct 21, 2009 | 03:32 PM
rich's Avatar
when my lp went out on my 03 the truck would not run at all. injectors can go bad without smoke they just let the fuel pass back to the tank. gone thru 3 sets on the 03 seen it all
Old Oct 21, 2009 | 04:26 PM
CrashCade's Avatar
Throwing it out there also. . . Injection pump. Mine started to do the same thing and then just stopped one day. I would test the pressures before Inj pump and the rail to see what is happening before throwing a good chunk of coin at something and it not fixing it!
Old Oct 21, 2009 | 07:32 PM
DPatton's Avatar
well i was having hot start problems as well, when the engine was cold she would usually fire right up but when warm it would crank long and gradually got worse and i have a little bit of white smoke at start up. also when it was running it ran fine, no noticeable loss of power.
DJ Turbo.
Oct 13, 2011 09:11 PM
gablekevin
Sep 19, 2006 12:12 AM
kawi600
Jan 26, 2006 10:19 AM
G-NOTE
Sep 1, 2005 06:36 PM
oscaroc
Apr 2, 2005 12:14 PM
