If edge juice is so bad, then whats the best for the buck?!
Old 09-25-2006 | 11:10 AM
staarma's Avatar
Originally Posted by qzilla
The range does prohibit you some, but not to 41 psi. The problem is in their software they choose to ignore anything over 39-41 psi.
You may be right but I think they are clamping the voltage at a smaller value like say 4.5 volts for boost fooling. Once that is done I don't think the sensor value will report or read a max of 4.78 volts or whatever they max out at 0-5. I'm assuming this is the problem. They could have "extended" the voltage table but maybe they didn't think anyone would be wanting more than that at the time of development. I don't know.
Old 09-25-2006 | 12:42 PM
wheelndealn's Avatar
If you want a "safe" module, go with the Edge, it will not let you hurt anything.
For serious power, go with the TST, but be ready for trans upgrades,and fuel system. take it like this...
Edge$900 and thats it.
TST($900)+tranny($2000-$6000)+fuel system($700).
Yeah, you can leave the TST on lower settings but, if you are like me you wont be able to help youself and blow stuff up.
Its just money
Old 09-25-2006 | 12:54 PM
Turbobob's Avatar
If you do your research, you can get a new Juice w/attitude for under 700 bucks. The edge, from what I have been reading, is not as aggressive with the power delivery & isn't as hard on the tranny.(Even my local dealer will warranty the truck with the Edge boxes, but not anyone elses)That's why when Santa comes, He'll be bringin' my Edge!
Old 09-25-2006 | 12:59 PM
qzilla's Avatar
It does not matter where they clamp it. They are clamping on the ECU side of things and not the MAP sensor side. The MAP sensor will continue to read until it is 100% saturated.
I think you are right and they just figured no one would care.
Quad
Old 09-25-2006 | 02:33 PM
staarma's Avatar
Quad
You are correct about fooling the ECU side. The sensor voltage is just that...voltage. My bad.
Old 09-25-2006 | 06:27 PM
swansong04's Avatar
Originally Posted by acook
Those guages are junk, theve been maxing out at something like 39-41PSI, get real guages.
well , i wouldn't say the gauges are junk .. the boost hits like 43 psi and well with a stock turbo i would say that is far enough.. i have both the analogue gauges and the attitude and they both read the same !! i have a had zero issues with my juice with attitude i have had it on for about 30000 km and have done allot of heavy towing (in level 2 of course) and it doesn't miss a beat .. i still grin from ear to ear when i play on 5/5 once in awhile .. and boy it is smooooooth !!! two thumbs up for the juice with attitude
Gary
Old 09-26-2006 | 05:46 PM
ocsurf16's Avatar
i see you guys saying to get the upgraded new versions of the Edge ..how can you tell what version or if its an older model...i posted an add that im llooking for one and most guys are tellin me 2 months old $550 with pillar???
Old 09-26-2006 | 06:04 PM
swansong04's Avatar
well when they are talking about the new version it could be one of two things ..
1. could be the hot juice version which you have to send in to edge for them to re flash the level 5 setting from 100hp to a 180 hp (i think it is a 180hp )
2.could be the new A2 and that is only the monitor that is upgraded .. but if the guy is selling it for $550 i really doubt it is that ..
i would just ask him if it has the hot juice upgrade ..
Good luck
Gary
Old 09-26-2006 | 06:25 PM
ocsurf16's Avatar
yeah i knew about the A2 and the Hot but i wasnt sure if differnt years of hte Edge's that were sold had old software in them causeing things to go wronig with some trucks
Old 09-26-2006 | 06:30 PM
swansong04's Avatar
usually the version and the date of manufacture is right on the juice and the attitude monitor ..
Diesel-Dan
20
09-22-2019 09:34 PM
regert
29
10-04-2011 08:00 AM
ckennedy
07-09-2006 04:25 PM
razor6
22
01-20-2006 03:43 PM
guyssets
04-27-2005 12:53 AM
Quick Reply: If edge juice is so bad, then whats the best for the buck?!
