I am shooting for 600 and im at stock, I have a long road ahead.
Old Jan 26, 2009 | 10:28 AM
Bowser50's Avatar
I bought my 04 last year and haven't had much time/money to wrench on it, been gone alot. I try to stay in the loop and read diesel world/diesel power religiously. I read about a guy who had an engine with a single turbo and put down 600hp, that's what I wanted 600 hp on a single turbo. I just got into the world of Diesel Performance and right now I am looking to upgrade my exhaust and intake then move on to a tuner, most likely looking at a smarty. I am living in CA right now and was wondering if anyone would have some insight on to some short term goals/mods/tips/hints/tricks to get me one step closer to my goal of achieving 600hp. any help would be appreciated.
Old Jan 26, 2009 | 10:44 AM
rock crawler's Avatar
IMO, in this order! Again, just my $.02!
1. Tranny
2. Gauges
3. Smarty
4. Fuel = injectors, pump, cp3
5. Turbo
6. Intake
7. Exhaust
Old Jan 26, 2009 | 10:48 AM
Dwitt0187's Avatar
i would start with a programmer and a lift pump it will also require some kinda of a modded cp3 a good stage3 a set 125hp injectors and a 66mm turbo should put you close to the 600hp mark and set heads studs would be a great idea for some insurance. and a 3250-3600# dual disk clutch
danny
Old Jan 26, 2009 | 01:06 PM
j-fox's Avatar
If you plan to tow or run up some steep hills, you will want twin/compound turbo's.
Old Jan 28, 2009 | 08:29 AM
kruegerlouie's Avatar
from my experience definetly do the turbo and exhaust at the same time!
Old Jan 28, 2009 | 09:21 AM
Hintz's Avatar
Gauges
DD clutch
Smarty
90-120hp injectors
stage 3 CP3
64 sized turbo (Either HTT's SS, E.D's, or II's bullet)
and your there
To had a little safety Id get some studs and valve springs.
Old Jan 28, 2009 | 09:51 AM
farmboykjb5.9's Avatar
Gauges
DD clutch
Lift pump
Smarty TNT
50 hp injectors
stg 2 cp3
HTT 64/71/13ss turbo
Old Jan 28, 2009 | 11:55 AM
jlibert's Avatar
1. gauges, lift pump(with 2 micron filter), smarty
2. DD Clutch
3. Turbo
4. Studs, Injectors, CP3
Intake and Exhaust can go on at any time. Make sure that the intake you buy is compatable with the turbo you want to get.
Old Jan 28, 2009 | 12:50 PM
omaharam's Avatar
Originally Posted by farmboykjb5.9
Gauges
DD clutch
Lift pump
Smarty TNT
50 hp injectors
stg 2 cp3
Farmboy's response is right on. You don't need studs and springs. You can also get close with stock injectors, but any injectors at all - 50hp and up, will get you the 600hp. You also don't need any larger turbo than mentioned above. Even the 64/65/13ss will support 600hp and will spool a little faster.
The correct order - IMO - would be:
Gauges
Lift pump
Clutch
Smarty
At this point you have a nice 500hp set up. Then...
Turbo & intake
CP3
Now you're in the 550-600hp range. Then...
Injectors
And depending on the injectors, your 600hp+
Old Jan 28, 2009 | 01:23 PM
Bowser50's Avatar
alright so the consensus seems to be a lift pump/gauges. I was thinking about a FASS, should I go with the 95 or the 150? and for a DD clutch what brand would anyone suggest?
Old Jan 28, 2009 | 02:57 PM
Bswope's Avatar
South Bend.........
Old Jan 28, 2009 | 03:05 PM
Hintz's Avatar
Gauges
Lift pump
Clutch
Smarty
Turbo & intake
CP3
Injectors
When you start getting in at 55-60+ boost PSI IMO, yes you do need studs and depending you how many miles you have, valve springs also. Cheap Insurance.
Old Jan 28, 2009 | 03:20 PM
omaharam's Avatar
Are you still running the stock turbo? I have personal experience with a 64 from HTT and a similar set up to what I said. He isn't going to see 60psi and doubtful that he'd see 55 either. He is going to be upper 40s and low 50s and studs are not needed at that point and neither are springs. I don't even have springs in my truck!
Old Jan 28, 2009 | 05:06 PM
Jason_K's Avatar
go w/ the 150
Old Jan 28, 2009 | 05:30 PM
Riflemanusmc's Avatar
Registered user
Fuel system........ MITUSA. Opie makes a great pump...
