I am shooting for 600 and im at stock, I have a long road ahead.
Old Jan 28, 2009 | 05:40 PM
justin allan's Avatar
Look at my sig then my hp and trq is at the bottom! You would think that I would be higher but not sure what else to do? I wan't more hp the only thing I can think of is getting 180hp injectors..
Old Jan 28, 2009 | 08:08 PM
nelrod's Avatar
Lots of good advice, these guys will steer you in right direction. Do think about whether you will need to pull with your truck in the future. If so, study up on egt's. and yes twins would be best. First Step -- Save a ton of coin.
Old Jan 28, 2009 | 08:20 PM
Brian Lent's Avatar
My numbers were better when I turned my smarty down to #5 tq 4 tm2 rp3, But even at settings 7 and 9 they were in the low 540's. I think maybe the dyno didn't load you maybe because you should have me by 40-50 horse I would think. Did they brake to build boost? was it in sixth? what was your boost? what kind of dyno? when I had mine dynoed it hit 45 psi and on the street it will get to 50psi. My brother could not get his turbo above 40 psi and dynoed 534 but will pull away from me on the street. My guess would be that you didn't get the boost to make the power you should of just like him.
Old Jan 28, 2009 | 08:23 PM
Jason_K's Avatar
hey brian, what size are your injectors? you and i have a similar setup
Old Jan 28, 2009 | 08:24 PM
Brian Lent's Avatar
They are said to be around 90-110hp.
Old Jan 28, 2009 | 08:48 PM
Yea it was in 6th gear and was hitting 47lbs of boost. I see 50 on the street some times 53lbs. I turned the boots elbow down for the winter now I am only seeing 43 or so. The Dyno way a Dynojet and said Smoothing:5 on it. I am going to go to the dyno and try the TNT and see what the numbers are. I have tryed it in my truck and it dose not feel as good as the 4.2 beta. For some reason I think my truck is not excepting the programing very well.
Old Jan 28, 2009 | 09:16 PM
Jason_K's Avatar
ok thanks, sorry for the hijack guys
Old Feb 3, 2009 | 12:31 PM
Bowser50's Avatar
what kind of mod should I go for on my cp3? or should I get a new cp3? or what about adding a cp3?
Old Feb 3, 2009 | 05:38 PM
omaharam's Avatar
stage 2 or yeah you could do duals, it will just cost you a little more money.
Old Feb 3, 2009 | 10:04 PM
Hintz's Avatar
IMO its dumb to get a stage 2 when you can get a stage 3 for a hundred or two more and not have to worry about upgrading to a bigger CP3, but if you can find a decent cp3 cheap get it. Twin CP3's are the way to go, unless your pulling and rules dont allow it.
Old Feb 3, 2009 | 10:06 PM
Hintz's Avatar
Originally Posted by omaharam
Are you still running the stock turbo? I have personal experience with a 64 from HTT and a similar set up to what I said. He isn't going to see 60psi and doubtful that he'd see 55 either. He is going to be upper 40s and low 50s and studs are not needed at that point and neither are springs. I don't even have springs in my truck!
Why chance it? Get studs. And for springs you dont know what shape his are in, or how many miles and how many have been towing. Again why chance especially now that they're cheap.
Old Feb 3, 2009 | 10:09 PM
Shagginwagon's Avatar
Originally Posted by farmboykjb5.9
Gauges
DD clutch
Lift pump
Smarty TNT
50 hp injectors
stg 2 cp3
HTT 64/71/13ss turbo
I like this plan.
Old Feb 3, 2009 | 10:34 PM
03qclb5spd's Avatar
My old 03 5 speed peaked at 55lbs but hung around 50 or so for the most part for close to 20k miles before the accident and I never had studs. I would have done them eventually, but since I wasn't driving a 6.0 Ford I wasn't too worried. That was with an II SB66.
Old Feb 4, 2009 | 07:12 AM
omaharam's Avatar
Maybe we should ask him how much money he has to spend since he asked how to make 600hp but you seem to want to give him advice on spending enough to make 800hp.
Old Feb 4, 2009 | 10:17 AM
Hintz's Avatar
Gauges
DD clutch
Smarty
90-120hp injectors
stage 3 CP3
64 sized turbo (Either HTT's SS, E.D's, or II's bullet)
and your there
To had a little safety Id get some studs and valve springs.
Boy you must be heck of a tuner to get 800hp out of what I recommend. And your right the extra 600bucks does get you 800hp, were do you come up with this? Also, how do you know how much money he has. And before you ask I dont, just giving suggestions, for a sense of security. And talk about spending money were not need o-ring heads with a tow twins.
