Hooking amp to Infinity System
Okay, I did a search but nothing came up on the problem I am having.
I hooked up a line level converter in the dash to the 2 rear speakers so I could run a couple of subs. For some reason there is always a low level of music comming through the subs even when I turn the volume all the way down to mute. The sub volume does not seem to increase or decrease with the volume of the radio....it just stays at this low level.
I am thinking it may be the converter since it is not like one I have used in the past. It is a 4 channel converter that I got from WalMart that has speaker level input AND outputs which seems a little odd. I didn't use the outputs, I just spiced into the factory harness. The instructions weren't real clear on what the outputs are for.
Thoughts???
Thoughts???
When I went to do the same thing, several install shops said that the infinity systems were famous for being really difficult to tap into.
It is an ohm issue.
The infinity system is a 5 channel. They said it would be easier to change out the head unit, then hook up your amp. Normally I do my own installs too, but I would take that one to a good install shop and give them a shot at it if you want to keep your stock infinity system.
It is an ohm issue.
I don't know if this helps you or not, but while searching forums about the RAH radio, I read that the infinity is a low-level system with amps at each speaker. Also read that in the non-infinity systems like mine, the factory speakers are 2 ohms. I really don't know myself, but maybe some others can help clarify this information?
I had the same problem you need to tap off of the rear of the head unit on the preouts [not sure what color wires] and then take that to your speaker signal to rca converter then to your amp. I had a hard time with it finally after 4 hrs the installers at circuit city figured that one out.
I did the exact same thing on my truck when I installed my amp. I finished the install, put everything back together, and I had no Bass out of the sub. It took me a while to figure out that the rear door speakers are Mid-Bass and higher only. There is no Bass signal at the wires to the rear door speakers. I had to dig back in the next day and wire the convertor into the front door speakers.
You'll be happy with the Infinty system if you putting in a Sub and Amp.
Have fun!
Have fun!
Not sure if this applies or not...
I got the el cheapo 4 speaker system, switched out those 4 for aftermarkets, realized I needed a sub then, shop went to install 1 10" under the passenger rear seat with 200 watt amp, ended up needed a 400 watt, they said the 200 couldn't pull enough signal from the head unit (at least I think that's what they said) so had to go with a 400 watt. With the 200 you had to crank all 3 eq's up to get a signal which distorted the other speakers, with the 400 can back all bass out of those, I can crank mine to 35 now and no distorsion...
I ran a amp and sub off the wires behind the right side kick panel. Here is a great link that has all the wire colors and a great write up.
https://www.dieseltruckresource.com/...threadid=62470
I found out what the problem is. From what I have read, Dodge switched the 05's radio output to a digital format that goes to the amp. So you can't just splice in a line-level converter at the radio nor does the PAC convertor work on the 05's. Just thought I would let some others know as this baffled me for a while and no one could give me an answer.
I ended up just spicing into the harness behind the right kick panel as some suggested. Not the best way to do it but it was my only option.
IsItFast
17
Apr 21, 2009 04:34 PM
Brewpie
Feb 1, 2008 09:02 PM
EverydayDiesel
Nov 29, 2007 12:14 PM
signature600
Sep 16, 2004 02:35 PM
moopa
13
Jan 5, 2003 08:26 PM
