Homemade 6" Air intake, AKA the "whistler", tech write-up **Part 2**
Old Apr 14, 2008 | 12:38 PM
  #136
mcolectd's Avatar
v2.0
I'm pretty happy with this set-up I just got it installed today. I don't like the trim I put on it but the "good" weather seal I ordered is not here yet...
wait till I get it all powder coated it going to be PIMP
Is that piece of tubing on the end going on to the filter the same as the original, just turned or is it a whole new piece? If its new, what is the part number?
Old Apr 14, 2008 | 12:42 PM
  #137
53 willys's Avatar
the 90* attached to the "box" is a Short radius 90* vs the other one being a regular 90*...there is a piece of 6" tubing welded through the lid of the box and the original amsoil 6080 was used...the part number is here some where I would have to look back through to find it...so stand by and I will see if I can find it
Old Apr 14, 2008 | 12:45 PM
  #138
mcolectd's Avatar
Ok thanks. I've ordered all my parts, just waiting for them to come in the mail. I wish I woulda waited and read this post before I ordered, so I wouldn't have to order a new elbow. I ordered parts based on the old list. I'm gonna try to build my own box from some aluminum diamond plate I've got laying around in the shop
Old Apr 14, 2008 | 12:50 PM
  #139
53 willys's Avatar
yeah I guess I should have the mods add the newer parts to the old list...I would have done it but you can go back that far and edit posts unless your a mod/admin
this is the elbow I used....
http://intakehoses.com/Merchant2/mer...gory_Code=9DEH
Old Apr 14, 2008 | 01:13 PM
  #140
mcolectd's Avatar
Ok thanks I appreciate it, Ill prob just try to find a way to make this one work for now
Old Apr 14, 2008 | 01:55 PM
  #141
mcolectd's Avatar
Did you replace the turbo elbow yet, or is it still factory? I ordered a longer piece of 5.5" aluminum tubing and am going to just run that all the way to the turbo elbow instead of using the factory silencer. So I was gona get a new turbo elbow too if you knew which one I would need
Old Apr 17, 2008 | 10:53 AM
  #142
modified03's Avatar
I just gutted the tourque tube and put a amsoil4510 filter on it. Putting bigger tubing on there will make it whistle more??
Old Apr 24, 2008 | 09:02 AM
  #143
Chopper_Bob's Avatar
Guys, I ordered all of the components to make this whistler......This was a little more expensive than originally anticipated. I have got $180 in this thing already and still have to come up with some sort of heat shield and support mounting. The AMSOIL Filter was $80 and I have $100 in the tubing, elbow, and band clamps. Granted I bought 12" of both the 5 1/2" tubing and 6" tubing in case I screwed up any welding, but it still would have been $160 for everything. It almost seems worth the extra $150 to buy a manufactured intake? Do any of you have plans for the heat shield that you have built? When I say plans I mean a drawing with dimensions so that I could reproduce what you have already created. If I can't get a heat shield figured out I may have a *****'s Whistler posted in the clasifieds. If anybody can send dimensioned sketches of their heat sheild I would apreciate it. The guy who made the box and put the Lexan lid over the filter had to have sunk a lot of time into that set-up. It looks great! But I am sure that isn't something that you can make for $20 and a couple of hours unless you are real good with sheetmetal. Thanks guys. Any help would be appreciated.
Old Apr 24, 2008 | 09:05 AM
  #144
Dieseljunkie's Avatar
$80 for the filter? Did you pay full retail on that?
Scott
Old Apr 24, 2008 | 10:20 AM
  #145
It was something like $68 from the Amsoil Website that was posted and then I guess shipping and tax on top of that. It was something like $78 and change for the final bill. I compared to K&N for the same thing was $10 less but didn't really want the oiled filter. AFE's Pro Guard 7 was slightly over $100. So I broke down and bought the Amsoil. I tried to find a better deal on the net somewhere, but got tired of wasting time and just bought it.
Old Apr 24, 2008 | 11:15 AM
  #146
Originally Posted by Insayn
I just finished up a majority of the install on mine. I will get the AIT bung tig welded either tonight or tomorrow and drill a hole for the filter minder.
I made an aluminum shield for mine today. Took about 3 hours to measure and bend it up by hand on the bench. I don't know how much heat it will block, but it fits nicely. It has a 2" lip to mount to the battery tray and a 6" lip up front (can't really see it). The base is 11" with a bend to a 8" section by the alternator. I placed a slit in some vacuum hose and covered the edges.
How close are you to the alternator with this heat shield? I'm attempting to form something up from cardboard before I start using up aluminum. I seem to be running real close to the alternator. I wish that I could get a little more bend to get around the battery with the 6" tube. That would slide the filter over into the corner a little more. Anybody have suggestions.
Old May 29, 2008 | 11:31 PM
  #147
SHREK's Avatar
Sorry to bring an old thread back but I built one of these this evening. It sounds wicked. Thanks guys for all the work yall have put in to it. I have read just about every post yall have put up. It took about 20 min for me to do. I finished it up and think I want a 45 for it to push it in to the corner a bit more. Does anyone have a part number for one?
Old Jun 5, 2008 | 10:55 AM
  #148
mcolectd's Avatar
****** have you gotten yours powdercoated yet? I wana see what it all looks like
Old Jun 5, 2008 | 08:43 PM
  #149
modified03's Avatar
what is the diff. between the stage one and stage 2 and which is better?? where are the plans?
Old Jun 13, 2008 | 04:52 PM
  #150
cumminshakesit's Avatar
my parts are in the mail. thanks *****, that was painless, bout a 180$ w/ shipping. not bad... will post after install. thanks again.
