High EGT's / dyno
Old Apr 21, 2008 | 06:37 PM
Diggie's Avatar
High EGT's / dyno
Hey Guys,
I want to take my truck down the quarter mile, however, I'm a little reluctant as I can hit 1400-1500 pretty easily. What should my nexy step be?
Twins? Water/meth?
By the way, I put the truck on the dyno and made 450HP and 780 ft. lbs. I believe I should be able to squeeze a little more out of it, but I can't stop the tranny from downshifting during the pull.
Any thoughts?
Thanks!
Old Apr 21, 2008 | 06:47 PM
jmccart's Avatar
Are you running the 4.11 tune that is available on the website?
Old Apr 21, 2008 | 07:03 PM
Diggie's Avatar
Good question. I believe so, as I just purchased it a couple of months ago.
Old Apr 21, 2008 | 07:19 PM
jmccart's Avatar
Definitely double check. The 4.11 tunes run super cool. And unless you are running some beta and have a full built trans/clutch, the 4.11 are the tunes to run. I was shocked at how much cooler my truck ran with the 4.11 compared to my old Superchips, Diablo Predator, and the standard Smarty tune that came in the unit.
Old Apr 21, 2008 | 07:38 PM
Diggie's Avatar
Ok I'll check it out!
Old Apr 21, 2008 | 08:38 PM
jmccart's Avatar
Cool, I am curious since I want your turbo and I am guessing that turbo and a smarty are really cool runners. How free is your exhaust & intake?
Old Apr 21, 2008 | 09:11 PM
TORQUE BEAST's Avatar
with your turbo I would say that you probably have a beta tune. plug it in and post your numbers and we can help you out with what tune you have.
Old Apr 22, 2008 | 08:49 PM
Diggie's Avatar
I plugged the Smarty in, and it is the 4.11B version. It also says 'D2.11B"
My intake is an AEM, which I am about to switch out, and the exhaust is a 5" turbo back Magnaflow.
Old Apr 23, 2008 | 07:32 PM
jmccart's Avatar
I am running the 4.11/2.11 right now. It is a real cool runner. I wonder why the heck you are running hot? Especially with that intercooler & that turbo. I wonder if your gauge is accurate. What are you when you cruise down the fwy?
Old Apr 24, 2008 | 06:45 AM
Diggie's Avatar
I was curious about the accuracy of the gauge as well. Running down the freeway at 65mph, I am around 850 degrees.
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
Eat Beef
18
Mar 25, 2003 06:01 AM
gofastman
14
Jan 26, 2003 10:33 PM
