Help me build a Sled Puller
Old Jan 29, 2008 | 08:23 PM
Hawkeye 04's Avatar
Smile Help me build a Sled Puller
So my truck isn't need on the job anymore and instead of selling it, I'm turning it into a sled puller. So far, this is my list of "needs".
F1 Cam
F1 Springs
Flux 4's
Cp3 Stage 3
A5000 Turbo (no twins aloud)
Raptor 150 fuel pump
Smarty race 4000 rpm
Traction Bars
Weight bar
Suspension blocks
What in your opinion do i need to consider or change? Who makes the best ladder bars for the price? Where can I get a good deal on the turbo? So many questions.... so much money....
Let the opinions fly!!
Old Jan 29, 2008 | 08:28 PM
Hawkeye 04's Avatar
Also, I'd be willing to do a partial trade with my current turbo for a A5000.
Old Jan 29, 2008 | 08:29 PM
Rpainter's Avatar
you might want to read the rule book on size turbo around here the A5000 is a tad too big for the mod class
Old Jan 29, 2008 | 08:37 PM
Hawkeye 04's Avatar
The rules are 2.8 inch. What is the size of the A5000? I was thinking it would pass...
Old Jan 29, 2008 | 08:43 PM
strokethis600's Avatar
I would give haisley machine a call and get a second gen ats manifold, and hang a s400 with a 2.8 housing on it. I believe a modified s400 will out flow a 5000 and probably more dependable.
35" 05''s Avatar
u can always put a reducer on the turbo. and gdp's ladder bars are the Best design imo. I decided to build my own to look similar, but I just put bigger tubing. they've worked so far.
Old Jan 29, 2008 | 09:12 PM
nottanuff03's Avatar
What size of tubing did you go with? I'll be making my own as well and going with a GDP style. Any other information on material used would be great. I'm also curious about suspension blocks and ideas for that.
Old Jan 29, 2008 | 09:37 PM
82NDSNPR's Avatar
get out your check book.....
Old Jan 29, 2008 | 09:38 PM
Luvnacumns's Avatar
LOL!!!!!!!!!!!!!!!!
Old Jan 29, 2008 | 09:43 PM
35" 05''s Avatar
1 1/2 instead of 1". 1/2" flat stock. and welded rear custom brackets. gdp has the best and not going against them, just figured more steel wasnt going to hurt.
Old Jan 29, 2008 | 09:45 PM
35" 05''s Avatar
thanks a lot! now if it'd all just jump together for me..haha
Old Jan 29, 2008 | 09:46 PM
Luvnacumns's Avatar
Damg Chet, those look good!!! How did you get measurements and what not???
Old Jan 29, 2008 | 10:47 PM
bluechrome's Avatar
You might want to see if you can get one of those f1 pressure boxes as well and a modded rail. Squeeze as much fuel in as possible
Old Jan 30, 2008 | 12:41 AM
tristan21's Avatar
Might check around I remember hearing the weight bar was'nt able to be used in some classes due to a 8000lb maximum weight.
But then again Ive seen a few trucks with them. Must be a class spec???
Not sure what you weigh dry but youd probly be close to 8000lbs if you get a ****** Weighted shifter ball.
