Help with AFE Intake.
Old Aug 29, 2011 | 07:00 PM
gilaphreak's Avatar
Hey all. Looking to upgrade my '06 5.9l stock intake with an AFE filter replacement for an AFE full intake with the Pro Dry S filter. I have a few questions about it... First off which is the one i'm wanting? I have found 2 different intakes:
This one says it allows quite a bit more air flow than the other, but I had an open intake such as this one in my car and I believe it actually hurt performance (it being a warm air intake pulling air from the engine bay in stead of the fender)
http://afepower.com/shop/details_new...sel&brandID=53
This one is the one i'm leaning more towards. It being a whole box replacement. Looks as if it pulls air from farther down into the fender and grill area.
http://afepower.com/shop/details_new...sel&brandID=56
Furthermore. Am i correct in assuming that this will lower EGTs, as well as make it whistle louder? I had been looking into these earlier but the guy from a local diesel performance shop told me that i didn't want a whole replacement because it is easy to get water and mud in it. He talked me into the filter replacement which I am actually satisfied with. Just looking to get more whistle. All of the threads I've read say that an intake is the way to go. I have already removed the silencer ring but could tell no difference.
Old Aug 29, 2011 | 07:10 PM
JJPage's Avatar
The first one will give you more whistle...If I were going with AFE, I would purchase their Mega Cannon setup http://www.pmtdiesel.com/AFE_Dodge_D..._75_11343.html.
I actually prefer S&B's aftermarket cold air intake systems vs AFE's.
Old Aug 29, 2011 | 07:15 PM
gilaphreak's Avatar
The first one will give me more whistle, which is definitely good. But how does it compare performance-wise to the second? I prefer having crisp cool air from the outside rather than hot air from the engine.
Old Aug 29, 2011 | 07:47 PM
AkitaSumo's Avatar
If you want cool sure, I would recommend the home depot CAI modification. I will be putting the stock box back on with this mod on the future, once I have some free time...
Sent from my DROIDX using Tapatalk
Old Aug 29, 2011 | 08:42 PM
Chryco Psycho's Avatar
I assume you are using PVC piping from Home Depot , any more details ?
Old Aug 29, 2011 | 08:47 PM
gilaphreak's Avatar
So lemme get this straight... The first one will give me more whistle, while the second will be better performance-wise? Or will it not be a significant enough loss to make a difference?
Old Aug 30, 2011 | 08:40 AM
carl48's Avatar
the second one will give better performance but not as good as the stock box and psm or home depot kit with a wix 49946 filter
Old Aug 30, 2011 | 10:51 PM
AkitaSumo's Avatar
Here are some links covering the home made CAI...
https://www.dieseltruckresource.com/...&highlight=cai
https://www.dieseltruckresource.com/...d-t261925.html
Old Aug 31, 2011 | 09:06 AM
07BigHornRam's Avatar
i run the first one with the Pro-7 gold filter. I cannot compare it to OEM cuz when bought the truck the AFE setup was in this but with the Pro-5 blue. I only run a predator with puck on stacked performance. Turbo spools great and egt's never go past 900.
Old Aug 31, 2011 | 08:54 PM
JJPage's Avatar
Click on these, they are the nicest available, can get a dropped cold air scoop also; http://www.sbfilters.com/Cold-Air-In...Ram-5-9L-03-07
sinawalli
Mar 5, 2011 08:43 PM
surfram
Jul 17, 2006 02:06 PM
diesel_work
Oct 8, 2005 12:25 PM
sawboywv1
Jul 15, 2004 10:31 AM
thecatsfan
15
Mar 14, 2003 10:21 AM
