Heater coil light and bell chime
Old Nov 1, 2012 | 06:28 PM
JJP's Avatar
JJP
Thanks AH64ID I went to independent repair shop they were stumped my truck that I've owned 1 month is bone stock has 144,000 miles on it Dumas injection will rebuild injectors for 1,200 bucks dealer wants 3000 I'm just hoping injectors fix it because it also has to be cranked 5 seconds to start when warm its turn key cold will post cluster codes when I pick truck up from moss bros. dodge.
Old Nov 1, 2012 | 07:33 PM
Spooler's Avatar
If I were you I would only use F1 or Exergy to handle rebuilding my injectors. I have read too many horror stories of folks having issues with injectors repaired by many shops.
Old Nov 2, 2012 | 09:10 AM
AH64ID's Avatar
I agree with Spooler, you get what you pay for.
It either seems to be an injector or pressure relief valve issue.
Old Nov 2, 2012 | 02:00 PM
JJP's Avatar
JJP
Well thanks for both you guys help my family business has half dozen Dodges from a 96 with 550,000 miles on it we have 05, 02, and 00 year trucks but this 07 is the only truck that needs k1 and has issues, I'm not trying not to spend money on injectors Dumas injection is the place here in socal that everyone says is the best that 1200 is me doing the R an R on the injectors, smarty says the jr. will fix the light and bell chime so I might go that route for now thanks again for the help.. JJP
Old Nov 3, 2012 | 02:31 PM
JJP's Avatar
JJP
Originally Posted by AH64ID
What codes did you have that said the cluster was the issue?
I would find a new dealership, if you are out of warranty try to find a reputable diesel shop. They generally do better work, with better parts, for less money.
B160B,TWICE B2302,B160E,P0708,B1427, Original cluster was found to have 2 error codes when I had to go to dealer for K1 reflash, dealer said replace cluster plus alternator, took print out to used dealer they sent me to independent diesel shop they kept my truck for 2 weeks gave me back used cluster, lucky for me I took truck back to dealer scoped my truck now it had 6 error codes, independent finally fessed up that he put used cluster out of wrecked truck said used dealer would only pay for junk yard cluster,so now I have factory new cluster for 670 they said 800 but lowerd price because of all the stuff I've gone through used dealer says they will pay so will see, thanks for your help.
Diesel Junkie
Dec 23, 2014 03:01 PM
oliver92
Jul 1, 2010 05:40 PM
ian515
Sep 25, 2008 02:55 PM
Buffalo
Mar 15, 2006 05:26 PM
339K&Counting
Jun 6, 2004 12:13 AM
