Heater coil light and bell chime
My 07 had the k01 recall done heater coil light came on dealer said bad gauge cluster changed it out 800 bucks said problem solved is it? Dealer said they never heard of k01 causing heater coil light to come on I said look online.... HELP!!!
Sounds like it's one of the new codes that Dodge released. Dealer needs to refund your money for their incompetency.
NUMBER: 18-006-12
GROUP: Vehicle Performance
DATE: February 04, 2012
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 18-011-11 REV. B., DATED JULY
1, 2011, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE
HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE ADDITIONAL OVERVIEW AND
DIAGNOSTIC INFORMATION.
HELP USING THE wiTECH DIAGNOSTIC APPLICATION FOR FLASHING AN ECU IS
AVAILABLE BY SELECTING “HELP” THEN “HELP CONTENTS” AT THE TOP OF
THE wiTECH DIAGNOSTIC APPLICATION WINDOW.
THE wiTECH SOFTWARE LEVEL MUST BE AT RELEASE 12.02 OR HIGHER TO
PERFORM THIS PROCEDURE.
THE DRBIII® FLASH FILES FOR THIS BULLETIN ARE AVAILABLE ON
DealerCONNECT.
SUBJECT:
Flash: Diagnostic Enhancements For Fuel System
OVERVIEW:
This bulletin provides Engine Control Module (ECM) software enhancements to improve robustness to fuel system issue detection and two new Diagnostic Trouble Codes (DTC's). This bulletin involves selectively erasing and reprogramming the Engine Control Module (ECM) with new software.
Diagnostic procedures for these new DTC's are included in this Service Bulletin on the last 2 pages which may be printed.
The two new injector Diagnostic Trouble Codes (DTC's) for excessive injector return flow are:
· P1222 - LEAK DETECTION DURING MOTORING
· P1223 - LEAK DETECTION BASED ON QUANTITY BALANCE
**When the fault(s) occur, a solid Wait to Start lamp will illuminate in the cluster along with chiming 10 times. When the fault goes inactive, it will clear the wait to start lamp with no chimes**.
NUMBER: 18-006-12
DealerCONNECT.
SUBJECT:
OVERVIEW:
Edit- reading the right signature is fundamental. Do you have a Smarty OP?
Mine was just doing the same thing. I replaced the lift with a Fass thinking it might be bad. That did nothing. Still would toss the light and ding a bunch of times. I updated the Smarty (Oct, 5 release date) and it quit. Hasn't done it since. I'd start there. It's free.
I think i'd like to know if my injectors were about to do TU.
codes p1222 and p1223 plus truck now is hard to start when it's warm they the dealer say change injectors are the problem will fix it self I have no faith what if it doesn't 800 for cluster 2000 for injectors rebuilt
I wonder if MADS disabled monitoring of the new codes? It was originally stated it was a Chrysler glitch, but the people that were getting the new codes were actually having injector issues (on low-mild hp motors, not BIG motors).
I would find a new dealership, if you are out of warranty try to find a reputable diesel shop. They generally do better work, with better parts, for less money.
I never had the May file. I had a Feb file, then Mad had another update a month later (May like you said or April iirc). I went from a Feb file, to the Oct, 5. My trucks never been to the dealership for work. As soon as I updated to the Feb file (from a four year old tune), I started having issues with my truck and saw a 45hp 100tq loss on the dyno. After I went to the Oct file, the truck went back to doing good again. Mad told me bad FCA or lift. I repaced both (Fass and factory FCA), and the truck still through the pig tail light and would go into limp. I think Smarty had a bad file. Or the four year old tune, and the new Oct file are covering the codes.
Your truck doesn't have to go to the dealership to get new software, each smarty update has the latest Chrysler software. So any smarty update after Feb 4th has that above TSB incorporated.
The codes are for high return, not a lift pump or FCA issue. Injector or rail pressure relief valve are most likely suspect.
