headlite mod
hi i did the low beams on with high beam mod yesterday,took about 6 minutes and one click lock conecter,works awsome,i recomend this mod,thanx to the guys who originally posted instructions.i did a search and found it,its the violet with white stripe and a lite green one,you need to do a test to see which green one.works great thanx dtr
It was a mod posted by "RATTLE_RATTLE". I did a search in the forum for headlight mods and it came right up. ( It was the thread dated 4-12-2003) Here in Alaska where we have diminishing daylight 9 months out of the year I will definately be taking a closer look at his mod.
Last edited by Alaskaworktruck; May 30, 2007 at 03:16 PM. Reason: found original posting date
ut was on my 04,i read the post and he did it on a 02 so i figured i would give it a try and the wires were the same color,i didnt need to go under the steering column,i went under the dash towards the firewall,i had to test the grren wire for power when i turend the lites on,its a great mod,mite try the driving lite one too.
