Head stud install
Old Jul 16, 2008 | 11:47 PM
blwnsmke's Avatar
Head stud install
I bought a set of arp studs.. My truck is a 04 and just rolled 100,000 miles. When I do the install do you think it would be wise to go ahead and change the head gasket while Im in there? Ill be adding more power down the road so just want to do it once hopefully. Also when I put the studs in. Should I use some sort of locktite on the actual stud in the block?
Old Jul 17, 2008 | 12:38 AM
WUnderwood's Avatar
use the original headgasket, no need on locktite, use the lube they provide on washers and nuts
good luck
Old Jul 17, 2008 | 12:45 AM
blwnsmke's Avatar
So ya don't think I need to even pull the head totally off and change the head gasket?
Old Jul 17, 2008 | 12:56 AM
joesixpack's Avatar
No need if you already have a good seal, why mess with it? 100,000 just broke in......
Old Jul 17, 2008 | 01:26 AM
blwnsmke's Avatar
So do I just pull all the stock bolts out and leave the head in place and just set the studs in place? Maybe a dab of lock tite? Im just **** about things like that haha sorry
Old Jul 17, 2008 | 02:08 AM
WUnderwood's Avatar
NO locktite, take the stock bolts out one by one, and replace it with a stud, torque from middle, working your way out
Old Jul 17, 2008 | 02:19 AM
Mr Bee's Avatar
Blwn... What they are telling you is to remove one bolt at a time, replace it with a stud and retorque. Then proceed to the next bolt replace with stud and retorque. Work from the center fore and aft and once all are in, re-torque all to specifications. I would reccommend to drive several heat cycles and re-torque again. Supplied grease is to maintain acurate torque with out the friction of a non lubed nut and the friction/resistance it causes.
Old Jul 17, 2008 | 02:47 AM
Blueboy's Avatar
studs
Screw studs to bottom, then back off a 1/4 turn.
Old Jul 17, 2008 | 06:39 AM
04DEEZELRAM's Avatar
Yep one at a time....just make sure you get some of the arp lube...we will knock it out in one day!!!
Old Jul 17, 2008 | 10:16 AM
dodgezilla04's Avatar
also look up the torque sequence in a cummins manual. do the one for one and torques per that sequence.
Old Jul 17, 2008 | 10:33 PM
blwnsmke's Avatar
Why back em out 1/4?
Old Jul 18, 2008 | 12:09 AM
WUnderwood's Avatar
do a search on 'head stud installation'
Old Jul 18, 2008 | 08:34 PM
gus's 03's Avatar
also, if you dont botom tap it, be sure to notch the valve cover riser for the rear stud, otherwise you'll have an oil leek!
Old Jul 18, 2008 | 09:14 PM
82NDSNPR's Avatar
i tapped mine and still had to clearence the back stud just use a dremel and mark it out then grind it down till she fits make sure to get rid of all the metal shavings before you try to fit the rocker seperator plate back in
Old Jul 19, 2008 | 09:23 AM
BBRam's Avatar
And make sure you find the 6 studs that are longer than the rest, they will go outside of the cover, along the exhaust manifold. I also bottom tapped the holes, takes a 6'' long tap, I also had to grind the rocker housing for clearance of the rear stud.
lostcreek21
Mar 1, 2010 06:13 PM
hic316
38
Jan 12, 2008 10:03 PM
74dart
Jul 7, 2007 07:58 PM
judge88
21
Mar 26, 2006 11:32 PM
blackcloud
Jan 17, 2006 12:41 PM
