HE351 Turbo Swap info...
Old Feb 23, 2009 | 09:44 PM
  #76
kblranch's Avatar
I am going to buy one of the ATS plugs and try drilling and tapping it. I have already tapped the the bypass hole and put a set screw in it so I do not have to worry about bleed off.
Old Feb 24, 2009 | 04:26 PM
  #77
UNDER-PRESSURE's Avatar
With the ATS plug there is no chance of bleed off. All passages are blocked & sealed with o-rings. Drilling & taping the aluminum compressor cover is very easy & the boost elbow should be 1/8 npt... the same tap as most EGT probes.
Old Feb 24, 2009 | 09:28 PM
  #78
kblranch's Avatar
I was going to drill and tap the ATS plug for aesthetic reasons. Would make it look more like a "factory" installation. Just me I guess.
Old Feb 26, 2009 | 12:44 PM
  #79
TJeeper's Avatar
Originally Posted by UNDER-PRESSURE
The plug & o-rings were around $40.00. It's a very nicely machined, well thought product & well worth the money in my mind. Again this is not needed to use the turbo in a swap but does clean up the install. I've removed the solenoid, plugged the bypass holes, reinstalled the solenoid & that works also.
Hmmm, by email they quoted me $65 for the plug and seals. Anyone elso purchase one and if so how much did you have to pay?
Old Feb 26, 2009 | 01:53 PM
  #80
I just looked at my last invoice & the plug was $46.35 & the 3 o-rings were $5.70. Looks like the price is going up.
Old Feb 26, 2009 | 03:52 PM
  #81
D45's Avatar
D45
Does anyone the Cummins/Dodge part number is for the 04.5+ downpipe?
Old Feb 26, 2009 | 05:23 PM
  #82
04.5 up 4" Downpipe: 52121600aa
04.5 up 4" Elbow: 5161570aa
4" Clamp: 52121285aa
Old Feb 26, 2009 | 08:20 PM
  #83
ktm06's Avatar
Under-pressure I have an edge-ez is that going to be enough or do I need a smarty or something along that line to lower my egt's. I tow heavy thanks
Old Feb 26, 2009 | 08:29 PM
  #84
A SMARTY Jr. would probally work well for you & have lower EGT's than the EZ.
Old Feb 26, 2009 | 08:50 PM
  #85
powermad's Avatar
so i have the edge jammer turbo would i get better egts and power from a he351? the edge is a 58mm non wastegated turbo.
Old Mar 1, 2009 | 07:06 AM
  #86
What are the spec's on that turbo?
Old Mar 1, 2009 | 01:23 PM
  #87
D45's Avatar
D45
Turbo Specs:
HE341: 54/58/9cm
HE351: 60/60/9cm
Just to g ive you guys some reference:
BD Super B Single: 57/65/14
BD Super B Special: 64/71/14
Most HE351s can be found for $200-$400, with very little miles on them
Most aftermarket turbos will cost $1300-$2000ish
The HE351 is a very nice upgrade, for those 03-04 owners on a tight budget, who want more performance with some mild mods.
This is a great thread, with alot of useful info!
Old Mar 1, 2009 | 01:28 PM
  #88
D45's Avatar
D45
Stupid ?:
Elbow vs downpipe.....which is what?
Old Mar 1, 2009 | 02:32 PM
  #89
AH64ID's Avatar
Stupid ?:
elbow is the cast piece that attaches to the turbo. Downpipe is the pipe attached to the elbow..
Old Mar 1, 2009 | 03:34 PM
  #90
Riflemanusmc's Avatar
Registered user
And when you go to twins(And you know you will) you'll have the top turbo
paid for.......
