Guages
Old May 18, 2008 | 07:41 PM
Blueboy's Avatar
Guages
My Isspro pryo guage is acting funny. When I start truck, needle
goes to 1500 then goes back down and doesn't work when truck runs.
anyone had this problem.
Old May 18, 2008 | 08:37 PM
cameroneod's Avatar
Mine used to jump around a bit. I got some dielectric grease in the connections and all is good now.
Old May 18, 2008 | 09:56 PM
blwnsmke's Avatar
Mine is doing this now! Put the grease in which connections?
Old May 20, 2008 | 02:52 PM
blwnsmke's Avatar
bump one time any other suggestions
Old May 20, 2008 | 04:09 PM
snoyes's Avatar
Check your ground to make sure it is good. If I remember correctly the ISSPROs have an amplifier which could be suspect. Also make sure that the yellow and red wires where you attach the pyro are not making contact with one another...
Old May 22, 2008 | 11:03 AM
MichaelP's Avatar
Check all of your connections, including those to the thermocouple and the connectors into the amplifier box itself. If the connections are all good, and you're getting clean power and ground, then please arrange a return through the dealer you purchased it through. Please let me know what you find.
Thanks,
Michael Pliska
Old May 22, 2008 | 11:14 AM
snoyes's Avatar
Look at that, ISSPRO on the site. Can't get much better support than that...
Old May 22, 2008 | 02:45 PM
Shagginwagon's Avatar
I've heard that using solder on the pyro wiring will cause erratic readings as well. FWIW. Double check your ground.
yomitch
Nov 26, 2002 09:16 AM
tobyw
Nov 13, 2002 09:11 PM
phox_mulder
Nov 9, 2002 08:17 PM
Oct 8, 2002 06:52 AM
