guage time
Old Mar 23, 2009 | 11:37 PM
phantom 309's Avatar
guage time
I got my guages ordered. Boost, pyro and trans. Im pretty sure i understand the pyro expect for where is the best place to put the probe at?
Old Mar 24, 2009 | 01:11 AM
Guardrail's Avatar
You get the most accurate reading if the probe is installed pre turbo, in the manifold.
Old Mar 24, 2009 | 03:05 AM
TrkEnvy's Avatar
Agreed.. back three cylinders run around 100 degrees hotter than the front three.. give or take.. i have my autometer pyro watchin the back 3 and my tst watchin the front 3..
Old Mar 24, 2009 | 07:23 PM
So at about which cylinder should i place the probe?
Old Mar 24, 2009 | 07:39 PM
Nate-03 D's Avatar
#5 cylinder.
Make sure you drill and tap it right, don't be like me and not pay attention. Then you just ruined a great manifold. lol
Old Mar 24, 2009 | 08:11 PM
Midnite Warrior's Avatar
Not trying to scare you but be careful of how you do it. I don't know if I had a bad manifold or what. But mine basically shattered a little while after I drilled and tapped mine. If this happens to you, I would suggest going on eBay and shopping around. I did and found an ATS two-piece manifold for a good price.
Old Mar 24, 2009 | 10:51 PM
From what i understand predrill slow with a well lubercated drill and once it is close to going though start the truck then continue? Then tap the hole with a greased up tap?
Old Mar 24, 2009 | 10:54 PM
sqrl$$'s Avatar
That's what I did w/mine. Some will recommend removing it to drill/tap, but the instructions that came with mine said to do it on the truck.
Old Mar 25, 2009 | 09:44 AM
mj1044's Avatar
would you recommend drilling a smaller hole to start with then crank it and drill the right size one?
Old Mar 25, 2009 | 10:14 AM
055055.9's Avatar
Not necessary just make sure you have it running before drill bit penetrates though and while tapping and use grease on the bit and tap to keep shavings out of the manifold.
Old Mar 25, 2009 | 10:28 AM
Nate-03 D's Avatar
I drilled a smaller hole then started with the actual size. I also removed the manifold to eliminate any concerns. Didn't take but a half hour longer to pull it off.
Old Mar 25, 2009 | 08:18 PM
I thought it would be just as safe to leave it on as long as the truck was started?
Old Mar 25, 2009 | 08:31 PM
Nate-03 D's Avatar
I guess that would work, never thought about that option. I'd ask someone who was tried it before and see what they think.
You can take the 4 bolts that mate together the bottom exhaust flange and the top turbo flange and stuff a rag in between them or a piece of cardboard and then drill it, maybe even have someone hold a shop vac while drilling to suck it all up.
k_butz
Feb 23, 2007 03:42 PM
taken5875
20
Jan 11, 2007 09:38 PM
bigragu
Jan 24, 2006 11:16 AM
LarryJ
Dec 29, 2003 03:30 AM
