Got my Donaldson 51" muffler
Thanx TCR. According to a post in this older thread on the Donaldson & Nelson 51" mufflers, the flow specs are pretty close to one another. Read the one thread by Doug.
Thanx.
https://www.dieseltruckresource.com/...naldson+nelson
Thanx.
I read the post about cat removal making the exhaust sound raspy. I guess all this stuff is subjective as I removed the cat on mine and there is no raspy sound at all. It is simply deeper and slightly louder than stock.
Cat removal made for an easier install of the muffler as well due to having a straight line install.
Thanx for the time guys. Hey TCR, Is the pyramid/cone/baffle/thingy look like something that is easy to remove? Would removing it somehow mess up the integtrity of the rest of the muffler's internals?
Thanx.
Thanx.
![CoffeeTime](https://www.dieseltruckresource.com/forums/images/smilies/new1/coffeetime.gif)
I have used the Donaldson 51" with the baffle. It is very simple to straighten the baffle inside. If you have access to a metel oxygen bottle valve cover you can place that inside the muffler and use a heavy pipe to drive it past the baffle to open it up. Since the top of the valve cover is rounded it makes it open up perfectly... no complaints. The reason I have done this is because it is easier to pick up a baffled Donaldson in my area instead of ordering the offroad one. Good luck.
No, I have done at least (4) of them and no problems.
Thanx a bunch TXDRAM. You know this situation up & down. I will do it (of course my muffler guy has tank covers hanging around). I look forward to being done with it so I can stop thinking about it.
Thanx everyone for all the help. I got a bubnch of threads going on this while I ponder. Tuesday I will stop cursing thie board with my different questions on the same thing.
on there. Good luck!
Jbremount
0
09-08-2014 01:05 AM
CalypsoCowboy
08-20-2008 07:11 PM
PEAKSTRYDE
10-11-2007 04:20 PM
gipsl67
08-22-2005 11:58 PM
coolslice
33
11-25-2004 12:37 PM
