Got bit, first costly problem
Old Apr 13, 2007 | 10:37 AM
BothellDiesel's Avatar
Wow, I can't believe I had 2 injectors go bad on me after everything i've done, Fuel Additive, Changing filters frequently, filled up at PACIFIC PRIDE with filters. Wish I had the Glacier 2 Micron on from day one, only been on for 9000 miles truck has 38,000. The problem came to rise, more noticable, when I swapped out 50hp injectors for 90. Truck idled great but was shaking between 1800rpm-2000rpm. Failed a contribution test on cylinders 1 and 4 (83% and 88%). Put in 2 Reman injectors last night, SHAKES are GONE. If you have a new truck, get a 2 micron on now! People make fun of me about how **** i am taking care of my truck, obviously it didn't pay off. No more to Baldwin fuel and oil filters, their micron rating sucks. I'll pay the extra for Fleetguard.
Old Apr 13, 2007 | 11:46 AM
trik396's Avatar
Did you get any fuel in oil? If they didn't crack or a tip didn't come off, what exactly goes bad on them?
Sorry to hear btw
Old Apr 13, 2007 | 11:56 AM
contamination inside the injector body, check ball especially. No cracks or fuel in oil.
Old Apr 13, 2007 | 01:13 PM
95ram's Avatar
From what I've been hearing from tech's is the check ball go's out. From the way they make it sound it's not a matter of if but when.
dodgezilla04's Avatar
sorry you're having trouble kyle, did you end up sending those 50hp's back?
Old Apr 13, 2007 | 02:02 PM
Yes, I gave the 50hp injector tips back. I could not sell them
Old Apr 13, 2007 | 02:46 PM
darn. well good luck with your troubles
Old Apr 13, 2007 | 05:51 PM
wap's Avatar
wap
Sorry about your troubles, I feel your pain.
Whos sticks are you runnin?
Old Apr 13, 2007 | 06:34 PM
reidsram's Avatar
does this filter fit into the stock housing? what do i need to do to get one?
Old Apr 13, 2007 | 08:27 PM
M671054's Avatar
go to cummins filtration.com and there is a cummins filter chart just for dodge trucks depending on year, but also note that every time you replace the filter you risk contamination, fuel filters are not to be replaced at mileage intervals as car manufacturers lead you to belive but are to be replaced at specified
levels of restriction, i'm just starting to look into proper test locations and specs as i just got my 06 cummins, by the way baldwins do not meet ceco
specs at all look into it in the fleetgaurd website.
Old Apr 13, 2007 | 10:44 PM
reidsram's Avatar
thank you for the info
Old Apr 13, 2007 | 11:00 PM
PourinDiesel's Avatar
Guys injector problems are not just contaminate related...
Old Apr 14, 2007 | 12:15 AM
Update! Pulled apart both injectors at Dynomite today. They were CLEAN, barely dirty. We don't know now?
Old Apr 14, 2007 | 10:08 AM
XLR8R's Avatar
As Justin said - FOD isn't the only danger to injector tips.
What kind of rail pressure are you seeing?
jturuk
19
May 9, 2007 11:47 PM
ouchman
Apr 16, 2006 03:26 PM
A-Poc
Mar 20, 2005 07:52 AM
TurboTed
May 17, 2004 11:45 PM
Dec 29, 2002 09:43 PM
