GDP 2 Micron Filter Kit
Old May 13, 2008 | 08:58 AM
Franklin's Avatar
Hey dudes I was checking this kit out and it looks it it will only fit the stock intake horn? My question is w/ this work with a CFM+? It looks like I might have enough room.....also it is pretty easy to install?
Old May 13, 2008 | 09:11 AM
eldgenb's Avatar
If you are going to buy this kit I would buy the matching intake from GDP, its really nice and works with the filter and factory dipstick and gives impressive gains. not to mention its also the least expensive. On your question, its not the space needed to mount the filter on the cfm, its the mounting ability. Most manufacturers do not build provisions into there intake for stock mounting options.
Old May 13, 2008 | 09:23 AM
Roperteacher's Avatar
Yes the install is very easy. I have the stock intake horn but have plenty of room. Takes about half hour to install, if that!
Old May 13, 2008 | 10:30 AM
ptgarcia's Avatar
I'm pretty sure the GDP kit will work with the AFE horn also. Or at least the AFE horn has mounting tabs on the back like the factory horn, so I'm sure something could be rigged to make it work.
Old May 13, 2008 | 11:44 AM
jlibert's Avatar
here's a pic of the 2 mk with the GDP horn.
Old May 13, 2008 | 11:45 AM
bob4x4's Avatar
this pic may help
That is the GDP and AFE Intakes
Bob
Old May 13, 2008 | 06:24 PM
Fisherguy's Avatar
I'd be very leary adding a 2 micron filter if you've only got the factory in tank lift pump. It's only putting out 8 PSI at an idle with very little volume you'll probably end up with less adding the 2 micron filter so if you ever do a chip or programmer you'll need more pressure.
Why not just get an Air Dog filter which you can get a 3 micron filter for then you'll be covered both ways.
Old May 13, 2008 | 06:26 PM
ptgarcia's Avatar
No problem with my 2-micron kit and factory pump after 30,000 miles, 29,000 with a power adder of some sort.
Old May 13, 2008 | 07:13 PM
Yes, absolutely no problem with the Stock pump and GDP 2 micron. I have both and my Idle PSI changed very little before and after. I made sure with GDP that it would work OK!
Old May 13, 2008 | 08:54 PM
dslpwr81's Avatar
The MK-2+ System adds a high efficiency Fleetguard 2 micron filter between the stock fuel filter and your expensive injection pump. Our clean mounting design locates the new filter under your intake manifold for easy changes at service time.
But that's not all! The new MK-2+ also replaces the restrictive supply line between the stock filter housing and the CP-3 with the highest quality 3/8" lines and fittings. You get the best of both worlds. Maximum flow and 2 micron filtration all in one package!
The Fleetguard FF5320 and 3/8" lines used in the MK-2+ will support any level of performance modifications. Flowing close to 100 GPH at a pressure differential of less than 1 psi the MK-2 ensures no loss of performance while you reap the benefits of 2 micron filtration.
We do recommend an upgraded fuel system such as ouf GFS series for trucks running performance upgrades along with the MK-2+ filter system.
Old May 13, 2008 | 09:15 PM
FlaCracker's Avatar
Yep, the MK-2 kit is a great kit, fit and quality of components is excellent. I purchased the GDP Fuel Boss fuel system at the same time, makes for a great combo...no more lack of fuel or pressure!
I too think it is a good idea to go ahead and upgrade your fuel system at the same time, but just my two cents worth!
Old May 13, 2008 | 09:30 PM
dogger's Avatar
2 micron filter with F/W separator
I'm running the 2 micron filter with the F/W separator mounted on the driver's side frame rail just downstream from the the GFS 392 lift pump in place of the factory mounted fuel filter lift pump. Easy access but some people may consider my choice of filter mounting position a little vulnerable to road debris. A 1/4 inch steel plate in front of the filter pack mounted to the frame solves that problem.
L8r,...........dogger
Old May 13, 2008 | 09:36 PM
Fisherguy's Avatar
Really?
All I know is I could draw my FP down to zero PSI running Crazy Larry with just the stock pump, I'd think it would only be worse with the 2 micron kit (but what do I know?)
Old May 13, 2008 | 09:48 PM
dslpwr81's Avatar
Read my earlier post. GDP recommends the GFS. If you call them, they will tell you that you NEED to run it if you are running a box on high settings.
Old May 13, 2008 | 10:52 PM
Fisherguy's Avatar
lol
Yeah, go figure, Glacier recommends a Glacier pump!
Like I said though, you should look into another pump if running a 2 micron filter, that much we agree on.
