Gauges
Gauges
Which ones are the best and where can i find them with everything i need? I want to do a three pod pillar mount with boost, fuel pressure, and pyrometer. They are for the truck in my sig.
I just did a quadzilla recon gauge that I got from Larry at the DTR shop. It was a pretty easy and well instructed install, the gauge is not intrusive in the interior at all, and it flashes when you hit your pre setup warning levels. Its is dimmable too. It comes equipped for egt, trans temp, and boost. There is an optional kit for fuel psi.
Dipricols here and they are a close match to factory. Got a tri-pod, gauges, and easy wiring harnesses from Genos. That was back before I realized you could get all kinds of stuff right here from the store on this website. Gotta agree with supporting the website. Doubt you can get the wiring harnesses from here though..
