Gauge Question
Old Nov 23, 2005 | 06:30 PM
donnee's Avatar
Gauge Question
Having installed a pyro and boost gauge, I was curious about the numbers I have found.
After the install, I took a test drive to make sure nothing fell off.
The pyro sahowed around 600 degrees @ 70 and the boost was about .
IS this about right?
Old Nov 23, 2005 | 07:07 PM
ToyKraz's Avatar
I run about 800 on the temp. Never really paid attention to the boost when cruising at 70, but I think it hangs around 10.
Old Nov 23, 2005 | 09:30 PM
truckjunkie's Avatar
Is your probe pre or post turbo?
Old Nov 23, 2005 | 10:48 PM
StrokeThisCTD's Avatar
pre turbo i am about 600-800 degrees at 70mph. Boost is around 6psi
Old Nov 24, 2005 | 04:21 AM
TexasCTD's Avatar
I would say that is pretty typical. Pretty much in line with my readings.
Old Nov 24, 2005 | 08:37 AM
donnee's Avatar
Sorry I forgot to add the fact that the probe is pre turbo.
Old Nov 24, 2005 | 08:48 AM
AKCoastie's Avatar
with pre turbo i read around 600* on the highway between 55 and 70. Boost sits right at 10psi.
I've seen my boost shoot above 30psi if I gun it pass someone our get ahead, this normal? Has anyone else seen anything like this.
Old Nov 24, 2005 | 09:06 AM
trik396's Avatar
At 70, my pyro is at or under 600, depending on road level (flat or incline).
My boost is right around 6-8psi at 70mph, depending on road.
If I floor it, I hit 40psi boost ... All of this is with my bed loaded with
about 1/2ton of tools, etc.
Old Nov 24, 2005 | 09:44 AM
Loco.Breath's Avatar
My truck runs between 500 & 600 pre-turbo on level ground between 60 & 70 mph. Boost stays between 6 & 10 psi. My boost will shoot up to 40 psi if I punch it also , but then the wastegate kicks in, and it levels off in the lower 30's.
2005 3500 DRW QC, Silver SLT, 600, G56 6 spd, BDPP, Aero-Turbine 4040, Cool Hose intake tube, turbo silencer removed.
mtl0727
Oct 12, 2005 01:02 PM
Igor
Sep 13, 2005 12:47 AM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
