gauge help just installed them
Old Feb 27, 2007 | 03:18 PM
oneslowyfz's Avatar
i just installed my dipricol gauges they look awsome had a few questions when i accelorate on the truck and boost starts to build there is a really loud rattle coming from the gauges is this normal? and the second question im reading on the gauges a 28-30lbs boost reading when i accelorate really hard on the truck is that normal>? thanks in advance
Old Feb 27, 2007 | 04:15 PM
oneslowyfz's Avatar
anyone? i know someone knows what the 06 boost at
Old Feb 27, 2007 | 04:19 PM
JD Dearden's Avatar
The rattle is not normal are they loose or something. Maybe there is something shaking around somewhere.
Old Feb 27, 2007 | 04:20 PM
JD Dearden's Avatar
I can't remember forsure but I believe boost is around 35 to 40????
Old Feb 27, 2007 | 05:30 PM
gerry's Avatar
on my 05 the boost goes to about 32 and then settles at about 28-29 until I let off the skinny pedal
Old Feb 27, 2007 | 05:50 PM
Lark's Avatar
Should not rattle and the turbo should spike at around 36 psi on an '06.
Old Feb 27, 2007 | 07:24 PM
Sailpipes's Avatar
The rattle could be one of the wires, connectors or gauge lines rattling against the housing. I have a windshield pod and mine buzzes right at 1000 rpm. I think it's one of the wires, connectors or gauge lines vibrating against the housing.
Old Feb 27, 2007 | 09:06 PM
Gunpowder's Avatar
I just installed isspro gauges last weekend and my fuel pressure isolater buzzed at certain rpms. I then moved the banjo bolt fitting from the inlet of the cp3 to the outlet of the filter housing, and the buzz is gone. Wasn't sure if one of your gauges was fp or not, but if so that seems like the most common source for the buzz. Also, your boost sounds about right to me.
Old Feb 27, 2007 | 09:17 PM
dodgezilla04's Avatar
some dipricol gauges have been known to rattle, mine does it with the exhaust brake on and high rpm. call your vendor, he may replace it for you.
Old Feb 27, 2007 | 09:43 PM
AZn8v's Avatar
I have the Dipricol gauges on the pillar of my stock '06 and the boost gauge rattles as well. I assumed it was normal, but now I will take it out and check to see that everything is tight. My boost peaks at about 32#.
Old Feb 28, 2007 | 12:34 AM
wldcat's Avatar
Stop the rattles
I cured my rattles with the following:
- I drilled 3 places, 2 small holes on my piller mount about 3/8 of an inch apart and zip tied from the back side, place a few small pieces of felt in between the pieces this will keep them from vibrating.- Wrap the bezels with a single wrap of black tape, may have to use a fine rat-tail file to make a little room.- Lock tite on all nuts- ran my wires through 1/2 inch foam rubber insulation. Very quiet!
Old Mar 6, 2007 | 06:48 PM
oneslowyfz's Avatar
does this sound right called the guy i bought them from and he called dipricol they are sending me a inline reduser? he said if this does not help he will send me out a new gauge
Old Mar 6, 2007 | 07:15 PM
NB64's Avatar
The rattle in mine was the nuts holding the gauge were not as tight as it should have been. If you can turn the gauge inside of the pod then it's not tight enough. But DO NOT over tighten. You will get a crack in the pod
Old Mar 6, 2007 | 07:18 PM
53 willys's Avatar
I had the same rattle and they gave me a new gauge
https://www.dieseltruckresource.com/...d.php?t=119370
bigragu
Jul 4, 2015 08:17 AM
Jim Lane
Jun 28, 2014 11:27 AM
Nate-03 D
Nov 4, 2008 08:25 PM
stock600
29
Dec 31, 2007 10:41 AM
Jim Fulmer
48
Jan 29, 2003 10:21 PM
