fuel issues. AIRDOG??
Old Apr 24, 2009 | 07:06 PM
ol' 93 12 valve's Avatar
Exclamation fuel issues. AIRDOG??
I have a 04.5 the one in my sig. It died on my girlfriend going down the highway. I flashed the codes and its 0628 ( low voltage lift pump) I pulled the fuel filter out and drained it, now no matter what i do i cant get the fuel filter canister to fill back up with diesel. Does this sound like a failed lift pump if so is it time for a Airdog??
Thanks
Old Apr 24, 2009 | 07:40 PM
6 Shaker's Avatar
Yeah it sounds like your lift pump has died
Giver on the Airdog or any other pump.
Old Apr 24, 2009 | 07:51 PM
i dont want to spend the 500 dollars and it not solve the problem. What else can i do to narrow down or insure that it is the lift pump? Is mine in the tank or is it the little black canister on the back of the fuel filter housing? I have checked the fuse box but none of the fuses are listed for fuel pump/ lift pump.
Thanks
Old Apr 24, 2009 | 08:13 PM
92'1stGen's Avatar
Sounds like it would be the fuel pump that is mounted on the back of the filter housing. Unless the truck has previously been to the dealership to have the in-tank fuel pump conversion. Either way it definitely sounds like the fuel pump is your problem.
Old Apr 24, 2009 | 08:54 PM
Spooler's Avatar
Yeap, the dreaded lift pump failure. It's toast.
Old Apr 24, 2009 | 09:09 PM
jiggerman78's Avatar
if you need a quick fix you can always get a holley pump in the mean time...I run a $60 procomp and its still alive...just inase you wanted a cheaper way out but its still 140 for a holley...
Old Apr 24, 2009 | 09:34 PM
The truck has never been to the factory for anything, first major problem with this truck. I want to fix it the right way the first time. I talked to a guy at airdog and he asked me where the lift/fuel pump was located and i told him i wasnt sure. So just to clarify is it the black canister on the back of the fuel filter housing.
Thanks alot
Old Apr 24, 2009 | 10:54 PM
hyperrcng's Avatar
visit Glacier Diesels website and read through the airdog instructions
http://www.glacierdieselpower.com/im...l%20Manual.pdf
look at page 10 of the instuctions fig 17 it shows your fuel filter canister with the fuel pump attached(small round black thing)
I just put the airdog 100 on my truck because it is almost plug and play. For the money it is the best buy, but you can always call Geno's garage for the factory pump. I think its still 200 bucks itself.
Old Apr 25, 2009 | 08:36 AM
excellent, i appreciate everyones help. The airdog 100 is on its way.
Thanks
Old Apr 25, 2009 | 09:02 AM
I order the one for 04.5-07 correct??
Old Apr 25, 2009 | 09:46 AM
rip 112's Avatar
Yeah it sucks the canister mounted lift pumps block fuel flow when they die. Bad design, if they would've stuck with intank pumps the whole time this problem wouldn't be so serious til more power was needed.
Old Apr 26, 2009 | 01:22 AM
hyperrcng's Avatar
NO, if your truck still has the fuel pump mounted to the fuel filter canister you need the kit for the 03-04. Already been down this road on my truck, and took almost a month for me to install mine. The main difference in the kits is that the 05 and up kit comes with just a draw straw and different wiring harness to tap into the fuse box under the hood. AD100 on the 03-04 trucks can use a quick click fitting on top of the fuel pickup/sender assemby but the trucks computer MUST control the fuel pump or it will set a code, so its own harness for those years.
01blackspeeper
Mar 23, 2012 04:52 PM
Tractor Truck
Jan 20, 2011 01:56 AM
JJK98CTD
Mar 29, 2009 10:45 AM
kdbvulcan
20
Dec 6, 2008 04:34 PM
J Lent
16
Jan 15, 2008 07:27 AM
