Airdog Fuel Preporator!!!
What pressures have you guys seen with the Airdog 150 with 1/2" lines? At idle? WOT? I need to buy a inline fitting to install my mechanical gauge, but the Adrenaline shows 15-17psi & doesn't move at wot. Sound right?
that's how it is on my 06 as well.....this is what I use to read FP at the CP3...it will screw right on to your VP44 fitting that came with your AD...http://www.vulcanperformance.com/ser...-Degree/Detail
They have it. This is what I need. http://www.vulcanperformance.com/ser...-fdsh-2/Detail
I just ran a tee off of my fitting coming off of the VP and hooked the Adrenaline sending unit and my mechanical guage fitting into that. I have this one from Vulcan. http://www.vulcanperformance.com/ser...r-to-VP/Detail The 90 came drilled and tapped for whatever plumbing you choose to stick in it. I assume yours is the same.
Anyway, you should be able to find a 1/8" female tee to hook everything into. I actually found one that had a male nipple on one end and female openings on the other 2, it worked great.
Hink, if you run any biodiesel be careful of that covered hose. Until just recently Vulcan was using hose that would not stand up to biodiesel and that covering would make it hard to see that the hose was falling apart.
you can run this inline before the vp44 for your pressure port
http://store.summitracing.com/partde...5&autoview=sku
Thanks, I don't have the low psi switch for the Airdog. I guess you have to order it seperately?
Thanks, My friend did the same thing in his truck. I was just wondering if the kit was suppose to be with the Airdog or sold seperately?
