Flux 2s and stock cp3
Old Jan 18, 2008 | 04:30 AM
Dieselhed's Avatar
I was in the same boat as you a month ago. I was also worried about fuel mileage. I went with the Flux 2's and couldn't be happier. There was almost no loss in fuel mileage. I think the little I did lose is due to the fact that I can no longer keep my foot out of the peddle . But once that wears off I should be back to where I was. I still have a Floor It stage 2 pump and an HTT 64/71/13 to go on so I am sure my lead foot will be with me a while. I am seeing similair numbers as JRussell with my stock cp3 as well. But do not hammer it too hard because of the stock turbo. Good luck
Old Jan 18, 2008 | 05:14 AM
Kman9090's Avatar
How do you guys get that with stock CP3? Even with my chips turned off and just flux I struggle to get 17,000. Even with the EZ turned all the way on I don't see any improvement. Out-Of_Here said that the rail pressure gauge won't measure right with a pressure box as it fools the Cp3 into thinking it isn't running enough pressure so it makes it read lower to flow more. He had a very interesting post about it. It pretty much said that if your are not running a pressure box you will not see all the horsepower as if you were running one. Maybe he will get on here and say something. I think his post was over at CompD though.
Old Jan 18, 2008 | 06:41 AM
wap's Avatar
wap
plug your rail guage in before your pressure box and you will see accurate numbers.
Old Jan 18, 2008 | 09:58 AM
OldSmokey's Avatar
I talked to Tim Barber yesterday, and he said definatly go with the 2s. He said they will work fine with a stock pump, I just need to turn down the TST and get everything dialed in. Then when Im ready for a new pump Ill have enough fuel to get near 700.
bradler
Feb 18, 2009 12:43 PM
OldSmokey
19
Mar 26, 2008 05:11 PM
cvcook
Aug 17, 2007 10:41 PM
metal_miner
52
Jun 23, 2007 02:52 PM
MoparRiggan
Jan 10, 2007 03:31 PM
