FCA question?
Old Jun 24, 2007 | 11:46 AM
Snoxracer's Avatar
FCA question?
My question is would a stuck FCA cause an engine code to come on? Just wondering is I have one that is sticking and causing poor throttle responce once in a while.
Thanks
Snoxracer
Old Jun 24, 2007 | 11:59 AM
Luvnacumns's Avatar
PM Will (WAP) his gave him fits but I can't remember if it threw codes??
Old Jun 24, 2007 | 12:08 PM
tristan21's Avatar
Im not sure if it will throw codes but I spent plenty of time deburring mine and I still have a little flutter. I suppose has anybody noticed a rise in temperatue. I used to never see over 1250* and now at top end I get 1400*.
Old Jun 24, 2007 | 07:06 PM
tbarbee1's Avatar
I modded my FCA and the Gear housing with the SC on performance mine gets hot quick. It would go way over 1450* if I let it. More fuel = More heat.
Old Jun 25, 2007 | 09:38 AM
tristan21's Avatar
So what can we expect from duals?
Old Jun 25, 2007 | 09:46 AM
53 willys's Avatar
buying mods for more air
it should throw a code for the FCA if it is sticking but nothing is a guarantee with these computer controlled beasts...IIRC Will's did throw a code but I forgot the number.....
Old Jun 25, 2007 | 11:27 AM
tristan21's Avatar
Like what a restrictive little fan in the intake like the tree guy or a supercharger? Oh well I needed water/meth anyhow for mpg while towing.
Old Jan 16, 2008 | 05:33 PM
Tree DR's Avatar
Air
You really want more air? I've got a way to do much more air than I have.
Old Jan 16, 2008 | 05:55 PM
GOT BOOST?'s Avatar
I had an FCA malfunctioning causing actual rail p. to be a little higher 3-10 thousand more, than demanded rail p. and it caused the 0148 code. So if the FCA is malfunctioning then yes it should cause a code. But the CEL did not light up the code was only noted when I checked for codes. Jay
Old Jan 16, 2008 | 07:35 PM
coreydr2003's Avatar
If any of you guys are runnin a pressure box try takin it completly off, that was my problem thought for sure it was the FCA
NickBeek
Mar 7, 2008 05:17 AM
toupee
Jan 17, 2008 08:30 AM
cwoodall
Aug 2, 2007 12:47 PM
draskobnsf
17
May 29, 2007 08:29 PM
