FCA Metering Valve Question
Old Jan 12, 2008 | 09:49 PM
toupee's Avatar
Hi all,
I have a FCA that stuck open that I am trying to do some work to. I am curious if anyone who has had there's apart can tell me how tight the clearance on the metering valve was. Mine did not just slide out as the article on relentless diesel suggests. I had to tap my fca on a 2x4 quite a few times to get the metering valve out. It does not just "slide" back in either. It will for about the first mm then it feels more like it needs to be pressed in. I've sanded the valve to avoid burrs or rough edges and as near as I can tell it's perfectly smooth.
Old Jan 12, 2008 | 10:11 PM
Smkndzl's Avatar
The FCA is normally open. takes a pulse width modulating signal from the ECM to close the FCA.
Old Jan 12, 2008 | 11:43 PM
toupee's Avatar
In that case I guess I had an FCA that was stuck closed. Either way, it wasn't functioning correctly.
Old Jan 12, 2008 | 11:51 PM
vzdude's Avatar
DTR's 'Go to Guy'
One thing is for sure....it needs to slide like butter, or you will have problems.
Old Jan 13, 2008 | 02:33 AM
Billm2004's Avatar
yes it should slide back in pretty easily, i had to tap mine out but putting it back in, it just slid right back
Old Jan 17, 2008 | 08:30 AM
toupee's Avatar
FCA replaced under warranty. Thanks for your replies!
winkdemon
ABDTR #5
Dec 27, 2009 10:53 PM
sallyman1
15
May 23, 2008 08:48 PM
draskobnsf
17
May 29, 2007 08:29 PM
john francis
Nov 27, 2005 12:51 AM
