Electrical Connections For Guages
Old Mar 25, 2005 | 12:34 PM
Neil58's Avatar
Hi all,
Looking for some electrical help. Where is the best place to tap into wiring for guage backlighting and ground? I would appreciate any help regarding wire location, color of wire to tap into, etc.
Pictures are also nice. I'm a novice electrician and need guidance. Thanks in advance.
Old Mar 25, 2005 | 01:00 PM
01350banshee's Avatar
Fill out you profile so we can help you. DC colors change year to year, but I'll get it for you when I get home if you have an 04 and up. I used light switch power (orange/white lead 6) and factory grounds (black wire) with no problems. I'll check to make sure of that for you.
Old Mar 25, 2005 | 01:03 PM
Neil58's Avatar
Thanks for the quick response. Profile has been added.
Old Mar 25, 2005 | 01:07 PM
Sailpipes's Avatar
For the hot lead, there's an orange wire with a black stripe in the bottom row of wires coming from the headlight switch box. Don't use the black one with the orange stripe. Had to find the right one through trial and error so learn from my mistakes. The whole panel with the headlight switch and vent just pulls right off. This wire makes the backlighting come on when you put the parking lights on and also controls dimmer function. Basically so they work just like the dash gauges. I used a T-tap connector from the Di-Pricol universal three gauge wiring kit. For a ground, I just found a screw that was screwed into metal and used a ring terminal. I'll get a pic of this in my gallery for you.
Old Mar 25, 2005 | 07:21 PM
Thanks for the correction on the power lead. As for the ground, I tapped into the factory ground.
Old Mar 25, 2005 | 07:38 PM
Neil58's Avatar
Thanks guys for the information - it helps me out quite a bit.
Sailpipes - thanks for posting the picture and pulling off the panel information.
Old Mar 25, 2005 | 08:19 PM
RenegadeT's Avatar
Hey, I'm installing a triple gauge pod on the dash and have a question about the backlight wiring. Can I just daisy chain the like terminals (ground or hot feed) on all three gauges, then run one wire to the to the headlight power source or ring terminal for ground? I don't see why I couldnt, but I'm not that expereinced with this wiring stuff
Old Mar 26, 2005 | 06:42 AM
MikeyB's Avatar
Yes, you can. The current draw for the little bulbs in the gauges is very low.
MikeyB
TJE
Oct 1, 2012 04:47 AM
jragan
Sep 2, 2007 06:14 PM
miketriton
Oct 9, 2004 08:07 AM
RHC
Jul 7, 2003 06:03 PM
Commatoze
Dec 22, 2002 07:26 PM
