Electrical connections behind the glove box ?'s
Old Sep 29, 2012 | 12:34 PM
TJE's Avatar
TJE
I took the glove box totally out....I know where the RWAL connection is located. Just inside of the glove to the RIGHT is an electrical connector....what is this going to?
Thanks, Tony
Old Sep 29, 2012 | 12:41 PM
85crewcabbie's Avatar
unknown plug
Without knowing the number of pins in the connector I can't say for certain. But I have noticed that many diesel interior harnesses are wired for options a specific truck may not have installed. Given that its likely it's the plug for an electric window/power mirror/power lock equipped vehicle. I don't have a wiring diagram specifically for a 91, but could look at a 92 if I had a specific description of the plugs pin count, color, and sex (male or female pins).
Old Sep 29, 2012 | 12:43 PM
unknown plug
Without knowing the number of pins in the connector I can't say for certain. But I have noticed that many diesel interior harnesses are wired for options a specific truck may not have installed. Given that its likely it's the plug for an electric window/power mirror/power lock equipped vehicle. I don't have a wiring diagram specifically for a 91, but could look at a 92 if I had a specific description of the plugs pin count, wire colors, and sex (male or female pins).
Old Sep 29, 2012 | 12:53 PM
user name's Avatar
A picture might help us help you a little.
Old Sep 29, 2012 | 07:19 PM
TJE's Avatar
TJE
a picture! ha ha! you all must think I know my way around a computer....I haven't the faintest Idea how to post at picture. I know it's in the sticky.....I'm still clueless. I'll see what I can do.
Thanks, Tony
Old Sep 29, 2012 | 08:32 PM
simplysmn's Avatar
is it on the firewall ?there is a heater relay and also if you have power window's the wiring connect's on the right side from the driver's side ??? maybe that will help
Old Sep 29, 2012 | 08:48 PM
TJE's Avatar
TJE
yes its on the passenger side. 90* from the opening. I'll try to post a pic at some point....just wondering what it is
Old Sep 29, 2012 | 10:46 PM
simplysmn's Avatar
Is it mounted to fire wall /or is it a Black box ?
Old Sep 30, 2012 | 07:35 AM
j_martin's Avatar
Old Sep 30, 2012 | 11:43 AM
picture helps but not necessary
While a picture is very useful and saves time in this situation, a good description is all that's really needed. plug color, number of wires(pins) and their colors, and sex of plug (male or female pins.connectors) are really all thats needed. Please excuse the double post earlier.
Old Sep 30, 2012 | 09:43 PM
Chrisreyn's Avatar
I believe you are looking at the connector for the Daytime running light option and/or the snow plow lighting options...
Old Oct 1, 2012 | 04:47 AM
Jim Lane's Avatar
Red face
The blower motor resistor is also located in the vicinity of the RWAL, should be a 5 wire connector plugs into the airbox just above the RWAL module, to the lower right there are 2 connectors in the harness that connect the power windows, door locks and power mirrors to the passenger door at least on mine with LE package.
Snow plow option should be at the base of the column near the top of the dash.
Jim
crossy
Mar 23, 2013 02:08 PM
Baja
Dec 1, 2008 06:35 PM
badmrb
May 18, 2005 12:27 PM
Neil58
Mar 26, 2005 06:42 AM
Commatoze
Dec 22, 2002 07:26 PM
