egt out of control please help!!!!!!!!!
Old Oct 5, 2007 | 08:43 PM
Dwitt0187's Avatar
tonight i put my gauges in my truck and took it out for a test drive to see what kinda of boost my htb2 62/14 charger makes and to find out the pyro hit 1650 degrees in just a few sec. all i have on the truck is an edge ez and ddp 90 ho injectors am i getting to much fuel or not enough causing the heat i have a holley blue lift pump im worried that is not suppling enough fuel. and keep in mind the pryo probe is in the manifold not after the charger or is this normal and im over reacting
Old Oct 5, 2007 | 08:46 PM
omaharam's Avatar
What year?
Old Oct 5, 2007 | 08:47 PM
Dwitt0187's Avatar
2003 common rail
Old Oct 5, 2007 | 08:49 PM
rustyshakelford's Avatar
if the probe is accurate, then that is way to high. whats the wastegate set at and whats your boost pressure?
brett
Old Oct 5, 2007 | 08:51 PM
Dwitt0187's Avatar
it looks like it is set around 37 lbs
Old Oct 5, 2007 | 08:53 PM
omaharam's Avatar
You're short about 10psi. Get it adjusted and see how much that helps.
So how long have you been running your set up without gauges? You are a good example to people and why they should not add a bunch of fuel without gauges - you just don't know how much you might be hurting things.
Old Oct 5, 2007 | 08:58 PM
Dwitt0187's Avatar
i have have been running like this for about 4 weeks
i raced a friend of mine the other day and was above 100mph for about 1/4 mile so there is no telling what temp i was running there
so do you think it is not enough boost?????
or not enough fuel????????
Old Oct 5, 2007 | 09:22 PM
Dwitt0187's Avatar
where is everyone??????
Old Oct 5, 2007 | 09:30 PM
Luvnacumns's Avatar
Yes you need more boost.... for sure... take the ez off and see what that does too...
Old Oct 5, 2007 | 09:35 PM
Dwitt0187's Avatar
if i take the ez off i dont think it will spool the turbo ive drove it once with out the ez on it and it surges really bad
Old Oct 5, 2007 | 09:49 PM
MikeyB's Avatar
Sounds like you also need more advance timing. With the bigger injectors there is a slight advance in timing but more is needed with that much fuel you're throwing at it.
MikeyB
Firstgenfanatic
Nov 8, 2009 04:05 PM
SuperiorRam
Mar 15, 2007 03:10 AM
taken5875
13
Jun 1, 2006 08:23 PM
bhoeffner
15
Aug 6, 2004 04:52 AM
TexasDiesel
Dec 27, 2002 10:47 AM
