EGT out of control
EGT out of control
Hey Guy's
Hoping I can get some good feedback on this. I just installed my Volumizer yesterday and went for a test drive. I love the unit, however I have an EGT problem. On the 100 HP setting the EGT can exceed 1400 easy. At WOT 1400 comes in what seems to be under a couple of seconds. It would continue to climb if I did not let off the throttle. Is this normal for the 04? If so any ideas on how to get the EGT under control? Also will it cause any damage hit that number for a short time (under 10 second)?
I have a 12v but I'm guessing same princeaples apply. Your truck looks mostly stock and thats a pretty hefty power gain. You need more air.. lots more air. I dont know about the 04 but on 2nd gens usualy intake and exhaust is worth a few hundred degrees cooler each. I think some 04 allready have 4" exhust though. So maybe just an intake? I pretty sure on my truck to get abig jump in power like that I'd need alarger turbo housesing too or bigger turbo in general. Hope some of that helps
Re: EGT out of control
Originally posted by bhoeffner
Hey Guy's
Hey Guy's
Originally posted by gdh11
You guys are getting way up there. I can barely get to 1100 with a load behind me and my foot all the way in it. There has to be something wrong somwhere.
Where is your thermocoupler installed, before or after the turbo? That reading sounds like a post turbo to me and if it is 1100 post is pretty toasty!
As for the EGT issue, The only true way to get rid of heat out of these HPCR cummins is by a diffrent turbo set up. Most of these trucks are 305 or 325 HP with a tiny 9cm2 exhaust housing on the turbo which is very restrictive. All this combined with a 100 hp chip will not help any.
Originally posted by Forrest Nearing
did you increase the boost to help burn the fuel?
Forrest
Forrest
The Banks 6G with its timing feature also helps by at least 100 degrees, if not more. He's actually about were I would expect him to be with his modification list. I personally don't think there is anything wrong at all.....
Scotty III air intake, 4" exhaust with Aeroturbine and a Turbo Air Guide (TAG). All of these will help to lower EGTs by getting more air in and more air out. If this isn't enough them you may need to consider a replacement turbo.
