Edge user??
Looking for upgrade I pull camper, haul wood etc. looking for little more with out hurting trans or 6.7, I new to Diesel, need to know if it need to keep and eye on gauges, boost etc. What to look for and What to look out for????? Thanks
I've ran the Edge juice for two years now with no problems, have the hot unlock and turbo timer, with a set of gauges and flexability of power levels, and with all the safety features I like mine quite a lot, yet if I had nothing and wanted the best programmer the Smarty hands down.
I thank all for the input, I ve installed the EDGE today with the A post assc. Works great been doin alot of research to know excatlly what im dealing with. Love the edge, auto shut down, installed the EGT probe, all the setting and I know what to look for, couldnt of done it with out you all
Buddy has an 08 with the EDGE
You will be fine as long you don't really beat the hell out of it.
He is on his 3rd torque converter in 8000 or so miles. He has only smoked the two of them because someone has challenged him to race and he does a boosted 4wd launch. Converter protests!
As long you don't do that you should be fine. He beats the hell out of it the rest time and hasn't had any problems.
He picked up about 2-3 mpg by taking out the particulate filter and cat. Running stock muffler and resonator(its a mega cab).
with Attitude you have alarms after you preset you set for EGT, temp, ETC, so no you do not have to look at the gauges, and also the edge has the safety bulid in so it auto changes back to factory or above to keep from hurting your Bid D,
bws
Apr 19, 2005 09:18 PM
