Edge stutter/miss
Administrator/Jarhead
Edge stutter/miss
I have a hot edge juice with attitude, and when I am staging at a light or powerbraking to build boost on level 5, I get a miss...kinda sounds like a ricer on the line missing.
Seems like timing, maybe I can get a vid of it later and post.
Any info would be appreciated...
TIA
-mad
TIA
-mad
Your running out of fuel your rail is going dry. to fix that either run lower setting or upgrade cp3 or get duel cp3
if you dont have a pusher pump that might help
but your sig says a couple of mods so i really dont know what to tell ya
Insnt the edge mostly timming and duration? My juice on L-5 has plenty of fuel with the stock set up. Rail pressure and fuel pressure both OK per quadzilla guage.
Maybe something else, unless the stock set up is going away. But, more/better fuelling will do nothing but help.
Mine is hot, I have a pusher pump that gives me 28 at idle, and 22 at WOT, and a rail pressure guage that tells me that I am good. ??? I'll do it again later and really watch the rail pressure guage. It only does it when I am powerbraking and the tires are not spinning. As soo as I launch, or I break traction, it stopps.
Thanks for the input...
Charlie8301
15
Feb 27, 2005 09:09 PM
