Engine stutter, miss
Old Apr 3, 2008 | 07:38 PM
77machomopar's Avatar
I got to start my new engine tonight after being put together and when i free rev the enigne with no load on it. it stutters or misses and struggles to gain rpm's but then i will gain quickly and still ruin rough. it idles perfect though. I have the pods and old smokey fuel pin. I didnt adjust the pump...yet. Any ideas why it does this. are the pods not getting enough fuel? its the 92 motor mad non-ic Thanks
Old Apr 3, 2008 | 08:05 PM
Alec's Avatar
My first guess would be a fuel supply problem. Air leak in the pick-up, clogged filter, bad lift pump. Are you getting white or greyish smoke?
Old Apr 3, 2008 | 08:13 PM
I am getting blue smoke because my turbo seals are bad and i ddint get my seal kit in yet. still waiting for it. I have a holley blue on it with the SimFlo bypass regulator.
Old Apr 4, 2008 | 05:48 AM
Anybody have any ideas? I checked all my lines for leaks and there are none. I am clueless on what it could be.
Old Apr 4, 2008 | 06:23 AM
G1625S's Avatar
Either still air in the high pressure lines or there's not enough timing for the POD's.
Old Apr 4, 2008 | 10:40 AM
I have the pump as far to the head as possible. If there is air in the lines wouldnt it also run rough at idle?
Old Apr 4, 2008 | 08:46 PM
Tonight a took out all the injectors and cleaned them and put them back in. then i rebled all lines. it got alittle better but still misses at mid to high rpms. at an idle i cracked each injector individually and them all get fule to them and they make the engine run rough when each one is cracked. So i am taking that as they are still working. Any ideas?
Old Apr 4, 2008 | 08:50 PM
99globalwarmer's Avatar
its a air leak in the fuel system somewhere, mine did the same things when i did the 1/2 line conversion. their is air coming in somewhere,
Old Apr 4, 2008 | 08:59 PM
Ill go through and check it all out agian tommorow. Thanks Ill let ya know the results
Old Apr 4, 2008 | 10:32 PM
bgilbert's Avatar
Said it before, timing piston stuck in advance position. Time to tear apart the pump.
Old Apr 5, 2008 | 06:27 AM
How difficult is it to fix the KSB on the pump?
Old Apr 5, 2008 | 09:08 AM
bgilbert. Since i dont have a wiring harness for this engine... guy i bought it from said everything was there and there was no chassis or engine harness. I jumped the KSB and it made it run alot smoother at mid to high rpms. It still misses very little.
Old Apr 5, 2008 | 11:06 AM
G1625S's Avatar
Well, if jumping the KSB made a difference, then the timing piston must be doing something. Maybe the pump gear is retarded a tooth---has it even been removed (pump gear)?
Old Apr 5, 2008 | 12:36 PM
daking's Avatar
i wount worry about the ip if you did the 1/2 lines, you have an air leak some were, it wil idle ruff, and run kind of crappy, if i go below 1/2 a tank of fuel it will do the same thing, just to busy to fix it, its probaly around the pick up part in the tank
Old Apr 5, 2008 | 06:21 PM
It idles fine though. only mid to high rpms. but jumping the KSb made a big differecne but it is till a little rough. I did 3/8 lines agina but put a holley electric pump on instead. The pump wasnt taken off at all.
