stutter/miss/cutting out??
Old Dec 3, 2006 | 04:58 PM
SuperDave4x4's Avatar
When I roll into the throttle(not flooring it) doing about 60-70 I'm getting this stutter/miss/cutting out and it will do this until I let off the throttle. I watched my fuel gauge and it didn't fluctuate or anything. Sometimes it does it bad and other times it doesn't. Also it wont do this while crusing around or pulling out, just when I roll into the throttle.
Any ideas?
Old Dec 3, 2006 | 05:06 PM
6WHEELER's Avatar
mine is doing it as well, fuel pressure stays good, boost anywhere from 20 to 30 psi. I cleaned the map and iat sensor it helped but didn't cure it. Still look for the cure.
Old Dec 5, 2006 | 02:24 PM
Could it be a clogged injector?
Old Dec 5, 2006 | 11:19 PM
futchd's Avatar
SuperDave,
When you find the solution, please let me know. My truck does this semi-regular from 3 gear into 4th. I will go a week with nothing then it will start the studder in 3rd then drop into 4th and everything is fine. When I am on the interstate pulling 1900-2000 rpm, and try to blow past someone, the engine will give me power but often studdering up to 2500 and always stoping when I idle back down.
I changed the fuel and air filters but that did not stop the issue. My father said it was injectors but I have not taken it in for service.
Please let me know what you find.
Old Jul 11, 2007 | 05:23 AM
carterw65's Avatar
I too am having this same problem. It only happens when I am pulling my trailer and under heavy load on the throttle. I have an appt with the local dealer to try to diagnose this, but I would rather take care of it myself. Anybody found a solution?
Thanks,
Bill
981/2 4x4 24v, All Banks can offer.
Old Jul 11, 2007 | 02:24 PM
6WHEELER's Avatar
I have boosted my fuel pressure up to 18 at idle and 16-17 at wot. Like someone suggested, the studder is still there, but it didn't show up on the dyno last month. still looking for a fix.
Old Jul 13, 2007 | 08:23 PM
JSPulliam21's Avatar
Guys, is it anything like this?
https://www.dieseltruckresource.com/...d.php?t=146116
and
http://www.cumminsforum.com/forum/98...nder-load.html
and
http://www.competitiondiesel.com/for...ad.php?t=11986
Be sure to check out the video, too.
http://video.competitiondiesel.com/v...6201761a26.htm
Luckyrogue
Jul 12, 2008 08:42 AM
77machomopar
Apr 9, 2008 11:01 AM
madhat
Aug 22, 2007 07:56 AM
gbone
May 23, 2005 08:49 PM
davelinde
Feb 21, 2004 08:24 AM
