Edge EZ or Bully Dog Power Pup
Old Mar 8, 2005 | 12:16 PM
StevenB05's Avatar
I was wondering which would be the best, Edge EZ or Bully Dog Power Pup? I seen a Dyno on the Edge EZ and it showed most of it's torque gains at higher rpm's 2500-2900. I couldn't find anything on the power pup and it just tells horsepower ratings. I would like to have most of my torque at 1600-2500. I pull a 8K pound 5th wheel camper and at 70mph my truck is running about 2100 rpm's. I live in the mountians, so there is some pretty big hills to climb. My Dad owns a Powerstroke so I don't want to be out done. Which product do you guys think would be the best for my driving? What would be the highest setting I could safely run my truck on? Or if anyone knows anything better let me know.
Old Mar 8, 2005 | 12:57 PM
tobyw's Avatar
Here's some pretty direct comparison results from identicle '03 H.O 6-speed trucks, one running the EZ and one running the Pup... Both trucks have Scotty III intake and 4" exhaust, 35" BFG tires, and cruise was set at 65MPH.
Pulling Jeep's on flatbed trailers, loaded weight within a few hundred pounds (~5000), the trucks ran neck and neck up the hills. The EZ was on Level 3 and the Pup was in "Tow" mode. There was one good grade where the truck with the Pup was pulling faster, but EGT's were also climing upwards of 1225... The truck with the EZ was still under 1150... This may be due to the cooling brought about by the extra boost from the elbow that comes with the EZ, but I'm not sure?? At any rate, for the most part, these two trucks were identicle pulling power-wise. Economy, however, is where the Pup seems to make the difference. For the same trip, ~400 miles, the truck with the Pup was almost 2MPG better.
Hope this helps?
Old Mar 8, 2005 | 04:48 PM
Kanab Ram's Avatar
Two entirely difference products. Like comparing apples to oranges. EZ is pressure only whereas power pup is mostly duration with a small amount of pressure. Right guys?? You will see a lot of EZ's stacked with power pups though.
Old Mar 8, 2005 | 06:47 PM
kyle@ftlb's Avatar
Muted User
The difference in mileage between the two is coming mostly from the Pup's altering of the timing. The power pup is going to be a better value (horsepower per dollar) than the EZ. Plus the pup gives you some room to grow if turbo and injector mods are in the picture.
But they are both good products, i dont think you will be disappointed with either.
Old Mar 8, 2005 | 07:10 PM
HorseHauler's Avatar
which one is the "safer" one for towing? pretty much equal in that aspect?
Old Mar 8, 2005 | 07:54 PM
kyle@ftlb's Avatar
Muted User
They are pretty much equal with the Power Pup on the Tow level.
Old Mar 9, 2005 | 07:42 AM
StevenB05's Avatar
Thanks guys for all the help this is my first Diesel. I think I will go with the pup but heck you never know I maybe go with both. Thanks
Old Mar 9, 2005 | 08:30 AM
Lightman's Avatar
StevenB05 I wouldn't limit yourself to only those two options. If you like edge, the Juice w/Attitude is much nicer than the EZ. Otherwise there are some nice in cab adjustable boxes out there like TST, Quadzilla, etc. The pup is nice that it has three levels, and is way more powerful than the EZ, however you can't change levels on the fly with either.
Old Mar 9, 2005 | 09:34 AM
WildBill's Avatar
Bully Dog also has an Outlook Monitor which acts as gauges and lets you adjust power in the cab, and has adjustable defueling and some other features
coobie
14
Feb 20, 2005 12:08 AM
dodgedude361
Feb 14, 2005 11:59 AM
sawboywv1
Oct 14, 2004 10:38 PM
