dynoed today
dynoed today
i dynoed my truck today and had mixed results. it was on a mustang dyno. on the stock setting my truck made 301/544. not bad for stock fueling i thought. next i went to level 3 where i normally drive. edge rates this as a 60/160 increase. the truck made 366/743. i was pumped. then i go to level 6 or hot. this is rated for 160/350 increase. the truck made 433/856. well below what was advertised. especally with my supporting mods. the only thing i could see was peaks and valleys on the dyno chart on the upper end of that pull. am i running out of fuel? the truck smoked good the whole pull but i dont have a fuel psi guage so who knows? any thoughts?
You can tell when your fuel pressure drops. It'll starve the CP3, which will starve the injectors and it will start to buck. Might of had a little tranny slip. Look at the values afterward?
If you didnt shut off the safteys that would do it. "..and it was leveling out" quote seems like just that. The egde shouldve flashed your warning though or made it real big on screen by itself while it backs out fuel.
With the Southbend DD I doubt you had any trans slipping issues. I agree with your mods I would expect to see more, i think some guys running just a stock truck with Smarty in a beta program are running in the 450HP area with the 2006s.
i have stock 265's but they were smokin, felt sticky like a drag slick afterward. should i call edge and see if they have any insight? also where do i get a cheap fuel pressure guage and what #'s should i seee?
VikingDiesel
19
Apr 23, 2007 03:22 AM
red12valve
Jul 25, 2006 07:34 PM
