Dual Fuel Pressure Gauges
i have 2 questions about fuel pressure gauges.
1. from what i've learned and read it sounds like lift pump pressure is more important to monitor than rail pressure, atleast for me at this point in the game i don't have a lot of mods. so i'm going to install a fuel presure gauge for the lift pump pressure. where is the best place to hook this up to on an 05'? i've heard you can do it at the injection pump and also somewhere back by the tank.
2. at some point i'd like to monitor the rail pressure too, but keep the amount of gauges to a minimum. is there a dual digital gauge out there that can do both lift and rail pressure? i have isspro gauges now but diprocol seems to be the only company that has a rail pressure gauge. i know quadzilla has the digital display for both pressures but there has been some issues with its accuracy.
any input and advice will be greatly appreciated. thanks in advance.
If you go with the edge juice w/attitude you will be able to check fuel pressure and it will do boost fooling(won't need your quad boost fooler).Being you already have a few gauges I would get a Smarty and add the fuel/rail pressure to the list.Gauges look cool.
You can remove a banjo bolt from the CP3, install a tapped banjo, add a barbed fitting, a short piece of fuel hose, add you electronic sender or your isolator, or if you're crazy run it directly to your gauge. Done deal and you are monitoring at the most important place... the CP3.
... or if you want to be screwing around truying to figure why your gauge is giving all sortsa weir readings use an isolator!
signed
crazy guy without an isolator
i say keep the fuel outside, my luck that line would blow inside my dash.
Here's the tapped banjo...
http://www.genosgarage.com/prodinfo....BF-LONG-TAPPED
Then you get a hardware store 1/8th inch npt fitting with a barbed end, say 5/16", then run a hose off of that to your sender. I too, recommend not using an isolator. I prefer an electrical fuel press gauge.
The gauge will come with a sending unit that scews into the banjo bolt. Your gauge will have a wire you attach to the sending unit.
ok. i'll have to order the gauge and see what comes with it. geno's garage has it for 127.00 and it includes the isolator and 8 ft. of tubing. that might be the way to go.
That is a mechanical gauge. Just wanted you to understand before you purchase it. Requires using antifreeze between the isolator and the gauge and sometimes.... they don't work well.
Electrical fuel pressure gauges are more that double that price but no problems.
i'll have to do some more research before i do anything. i want to stay with isspro so all my gauges are the same. i don't think isspro has what i want in an electric gauge though. if they have an electric fuel pressure gauge and sending unit thats the wayi would go, but i didn't see anything on their website.
The Quad gauge issue has been resolved. I received one of the first and has worked as desired for me. They begun shipping the improved version early Feb.
Go for it.
Damon
ok. thanks for the update. it looks like i may lean in that direction if i want both pressures.
91oldranchtruck
02-22-2011 11:57 PM
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
