Downfalls to nos?
Old Sep 21, 2008 | 11:45 AM
  #61
mulisha's Avatar
how about just using water/meth. alot safer and you can definately feel the difference.it gave me 48 extra pony's.
Old Sep 21, 2008 | 11:50 AM
  #62
82NDSNPR's Avatar
yea but the bottle give u benfits of both if ur on the track and using it for times then thats the way to go in my view u can get 100+hp out of a shot the water is great for towing and other aps i like mine but not the same effect as the gas
Old Sep 21, 2008 | 02:43 PM
  #63
jrussell's Avatar
Meth can increase cylinder pressure and be even more dangerous than N2O.
Old Sep 21, 2008 | 02:58 PM
  #64
82NDSNPR's Avatar
yep ask soulxoo he warned me so i just spray water need to get the gas though soon
Old Sep 21, 2008 | 07:13 PM
  #65
jrussell's Avatar
Wow, so you gained almost 50hp with just water?
I told myself I wouldn't use water on this truck, but if there's 50hp to be gained then I might just have to.
Old Sep 21, 2008 | 07:16 PM
  #66
madhat's Avatar
Administrator/Jarhead
I would not spend the money. I'm not happy with mine. Maybe if you get a custom set up... I'm not knocking the benifits of water injection, but I don't like mine.
Old Sep 21, 2008 | 07:32 PM
  #67
jrussell's Avatar
Well it does take some tuning to see benefits. You can't just buy a kit and expect it to work perfectly on your truck.
I had W/M on my 1st gen and was very disappointed after I first installed it. No difference in power or EGT's. After changing the single nozzle to dual larger nozzles and adjusting the pump/controller I was able to see a solid 100-150* difference in max EGT's while getting a nice gain in HP too.
Old Sep 22, 2008 | 12:34 AM
  #68
82NDSNPR's Avatar
no i did not gain any hp with mine i wont run any meth in the mix since it does cause added timing and will lead to alot higher temps in the cylinder comp to the gas. while the gas will give you both lower egts and power out the other end of the comp cycle. i trust my boy soulzoo he has been there and done that and i listen when top tells me what to look out for. and while i dont agree with what nx says that nos can have no bad side effect, "sparing to much nitrous in a diesel with only cause the motor to die". the fact is you can overspool a turbo and turn it into a gernade just as fast as shooting a rod out of the bottom of the gasser. so be smart talk to those that have used the gas before and be safe
4969joes
Apr 27, 2010 02:24 PM
Hammer Down
33
Dec 17, 2006 08:01 PM
Saxet Nomad
0
Mar 9, 2005 03:27 PM
scottrod
Feb 20, 2005 10:06 AM
Art
Feb 20, 2003 08:32 PM
