What are some of the downfalls to running 20* of timing
Old Apr 26, 2010 | 08:08 AM
4969joes's Avatar
I am trying to lower egts on the truck in my sig, so im considering 20* of timing. What would be some of the downfalls to this decision keeping in mind this truck is a daily driver and will pull heavy loads around 15k on occasion. All input will be greatly appreciated.
Old Apr 27, 2010 | 01:37 PM
4969joes's Avatar
surely someone knows what the bad things about running 20* timing are????
Old Apr 27, 2010 | 02:24 PM
dodgetrucker75's Avatar
more timing will raise cylinder pressures, so if you run high boost pressures, it will get you that much closer to poping the head gasket, also the heat transfer to the coolant is higher so overheating could be a better possibilty, but i have my engine out right now waiting on a cam, when it all goes back together im going to set around 19-20 deg, but i dont pull all the time
diggity dodge
67
Sep 22, 2008 12:34 AM
Hammer Down
33
Dec 17, 2006 08:01 PM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
