Do I need a boost fooler with my smarty?
I am only running the smarty right now and when i tow i only hit 28psi or so and the temps are 1250 to 1350. Would a boost fooler help with the temps, i know the 05 has an electronic wastegate. does the smarty do any boost fooling?
aftermarket turbo only. aftermarket injector program will add timing i believe. i havent tried the turbo program yet, but bob told me it would run the same only more boost. maybee others will chime in.
is anyone running the aftermarket turbo stock injector program with a stock turbo? I don't want to loose the version that I have if this doesn't work well.
I think that the latest one is Dec. 13th.
You definately want to run the aftermarket turbo / stock injector program....it's much better than the stock turbo / stock injector programs
Just watch your Boost PSI You can easily go past the 42 PSI limit (that's MY personal limit) I feel any more and it's starting to get out of the efficiency range and you are blowing hot air. I usually start to let off at around 38-40 PSI. I don't let of quickly but ease off. This helps prevent turbo bark.
Killdmycobra
Nov 12, 2010 05:15 PM
BigBully
Sep 15, 2009 08:44 PM
nrussell
Jan 13, 2008 07:00 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
