smarty/tst/silver 62- need quad boost fooler?
Old Jan 13, 2008 | 04:59 PM
nrussell's Avatar
With my mod's listed will a boost fooler be needed?
Old Jan 13, 2008 | 05:04 PM
skynyrd's Avatar
with the smarty you shouldn't need a boost fooler just download the updated software for the smarty with the aftermarket turbo and it will disable the electric wastegate. www.madselectronics.com
Old Jan 13, 2008 | 05:12 PM
nrussell's Avatar
Hey Skynrd,
I have the aftermarket turbo w/ stock injectors downloaded. I was just wondering because of the silver 62 not having an electrical connection any more. II supplied a resistor to plug into stock plug. Just wondering if i needed to "fool" some more for the silver 62 and it's potential. I do not know what it is set at from II.
Old Jan 13, 2008 | 05:13 PM
OldSmokey's Avatar
TST has a boost fooler built in. Just plug the resistor in and you should be good to go!
Old Jan 13, 2008 | 05:16 PM
skynyrd's Avatar
yeah but the TST will only fool it up to 40 psi the smarty will disable the electric wastegate completely and allow you to run what ever pressure without tripping a code.
Old Jan 13, 2008 | 05:18 PM
skynyrd's Avatar
"*The softwares for aftermarket turbos DISABLE the electronic wastegate as found in the 2004.5 and later engines. That allows you to run
any boost pressure (- with an aftermarket turbo! ) without setting codes thus defuelling. Those softwares do NOT need an external boost
fooler. To learn more about the so called "boost fooling" please read here."
direct quote from the mads electronics website!
Old Jan 13, 2008 | 05:19 PM
OldSmokey's Avatar
Really, I didnt know that. Mine boosts to 50+ but it must be because of the Quad X2.
Old Jan 13, 2008 | 05:22 PM
nrussell's Avatar
Thanks Skynrd I guess I'm good to go then. By the way this smarty/tst/silver62 combo is one mean SOB
Old Jan 13, 2008 | 05:25 PM
skynyrd's Avatar
yeah i have the tst/smarty stack and looking at doing a cam and twins in the next year.
Old Jan 13, 2008 | 07:00 PM
RamWheelsBy4's Avatar
The TST will do boost fooling at least to 60psi, that I know for sure. The TST can only display boost up to around 40psi, but that does not mean it is not boost fooling much higher. With my II SPS66 (with supplied jumper installed) and TST/EZ stack I can open the wastegate that is set at 55psi for a lot of the time down the track.
jmccart
Apr 5, 2011 06:13 PM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
rkelley
19
Jan 11, 2007 10:59 PM
LooseBoltsRob
Dec 8, 2006 06:53 PM
JohnInNH
Dec 2, 2006 12:08 AM
