Do I have a plastic intercooler on my 05? (pics)
Old Aug 2, 2006 | 11:00 PM
VikingDiesel's Avatar
Im NOT sure what to look for, but I think the whole things plastic. What does that mean exactly, how much power can it handle before it goes KABOOM!!
Old Aug 2, 2006 | 11:06 PM
White97GTVert's Avatar
Most definitely.. Plastic end-tanks.
I still have mine (hasn't blown yet) but I always get a little leary when pulling Snoqualimie Pass out here in Washington state and I've got 8-10k behind me.. Boost is usually around 40.
Old Aug 2, 2006 | 11:15 PM
qzilla's Avatar
Only the end caps are plastic.
Some seem to last forever, but 40+psi will kill them if you are not careful. It seems that most of them go when you are towing something heavy. I am not sure if it is sustained boost that does it or boost spikes that might occur when towing something heavy?
It is not really a matter of how much power, but how much boost and how long. I think if you are easy in the go pedal and easy out of it then you could be ok.
Quad
Old Aug 2, 2006 | 11:17 PM
RAMROD2006's Avatar
intercooler
is there any performance gains ie....mor boost with an aftermarket intercooler?
Old Aug 2, 2006 | 11:32 PM
Quad
So I can still run a TST on a lower level and a Killer B2 turbo? and be able to punch it?
Old Aug 3, 2006 | 01:32 AM
qzilla's Avatar
Unitl the ends pop off.
Then you can get DC to get you the metal one.
Old Aug 3, 2006 | 10:11 AM
so whats the MAX boost I can have? I am getting a TST chip and planing to run about to level 3 or so untill I get trans done and new turbo. Will my stock intercooler be able to hold up?
Old Aug 3, 2006 | 10:17 AM
staarma's Avatar
I would start looking for someone's take off if I were you. Stock they don't even seem to hold up that great. They only tried it for a half of a year before they found out what they had done. Start watching the classifieds here and over on the TDR. You don't have to be a member to look at the classifieds on TDR. Some guys have sold their's pretty cheap because they went to an aftermarket for reasons that escape me.
Old Aug 3, 2006 | 01:24 PM
05mxdiesel's Avatar
If you are running the TST with the wastegate modification for the 05, they will last. Only the edge guys are blowing them because of the high boost spikes. Stock turbo and wastegate mod done on mine it will hit 34 psi on a spike but then drop to 28-29. I only replaced my intercooler because of a good deal on the banks unit. Remember you are fooling the ecu to add more fuel and hence the computer is thinking it has a lower boost pressure. The TST has a nylon line that connects to the wastegate and using pressure just a like a boost gauge. The 05-06 trucks have an electronically controlled wastegate.
QWKRTNU
Jan 31, 2006 09:23 PM
05mxdiesel
Jul 11, 2005 02:32 PM
451Mopar
29
Jun 8, 2005 10:13 PM
6stringdiesel
Jun 6, 2005 01:22 PM
KBF
Mar 9, 2005 02:24 PM
